I am considering getting an 80 gal hybrid hot water heater and installing it before my current propane 50 gal hot water heater. The current 50 gal is working fine but is around 10 years old. The current problem is not enough hot water to fill the Jacuzzi. And water temp is turned up to max.
So I am planning on a 80 gal hybrid 120V model. It would not be hard to push the new one next to the current gas one. Re-do the water inlet to feed through the hybrid water heater. Plug it into outlet and enjoy the extra hot water.
When the current gas one goes I remove it and push the hybrid over a few feet.
I read you only get about 75% of the water heater tank capacity as the hot & cold start to mix in that last 25%.
