The show Myth Busters did a special on fuel milage and they tested Acetone. It turned out the car got less milage on Acetone. Unfortunately, they didn't research the amount and I think they used too much. IMO the myth still continues because the Acetone users say don't use too much or your milage will go down, lol. The fact is that did happen, so if that is true then maybe if you use the right amount it will actually go up. The fact is that it effected milage, allbeit negatively, but it still effected it. Man I wished they would have done some more research on amount before the test and put this myth rest either way. According to them the myth is busted, they say acetone doesn't give better gas milage.
