Howdy guys!
I seek advise again, I have a '03 Super Duty crew cab 4x4, 5.4L, auto, 4.10 gears. I'm running Lucas Power steering additive in the....... power steering tank. Diffs are 75/140 semi synth Ford. Transfer case and tranny are Amsoil.
I've used Amsoil 5w20 in it once broken in, it's served me well. I've also used Mobil 1 0w20 a few winters but it's not that easy for me to get so I'm staying with 5w20 for now. But with miles adding on, hard miles (company truck), it sees just shy of redline very often (tranny has Trans Go shift kit), and has high idle time. It's a heavy truck (6,500lbs empty) and spins 35" tires so even when empty it isn't "carboning up".
I've been thinking to stay with synthetic, but changing the viscosity to a 5w30 maybe? You see oils out there for "high milage" which now starts at 75,000 miles according to one manufacturer. I tow occasionally, and when I do it will see 4 grand on the tach and higher for prolonged periods.
What do you guys think, and thanks for the help eh!!!
Cheers,
Mike.
Cheers,
Mike.
