War of 1812
by pkunk - 02/16/20 09:40 PM
Difference in brake hose brands?
by dan_erickson - 02/16/20 09:30 PM
End of Holden...
by Shannow - 02/16/20 09:10 PM
Getting Film Off Wheels
by Nick1994 - 02/16/20 08:58 PM
Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
Daytona 500 engine related question
by OilUzer - 02/16/20 07:37 PM
2006 Subaru Forester 2.5 NA
by 762fermeandyou - 02/16/20 07:29 PM
DIY Paintless Dent Removal....
by dblshock - 02/16/20 07:17 PM
Bad sports teams
by 53' Stude - 02/16/20 06:42 PM
Valvoline 20W-50 Baja 1000 Race oil
by kstanf150 - 02/16/20 06:21 PM
How to stand on the roof of a Saturn Vue?
by atikovi - 02/16/20 06:09 PM
Spliceline wire connectors
by Donald - 02/16/20 05:22 PM
Found a few clearance oils at AZ today
by PantherFan88 - 02/16/20 04:55 PM
NASCAR electric
by CourierDriver - 02/16/20 04:52 PM
Valvoline Modern Engine vs Regular synthetic?
by PantherFan88 - 02/16/20 04:50 PM
Converting 1970 396 to Fuel Injection
by 007 - 02/16/20 04:47 PM
2016 frontier.
by red7404 - 02/16/20 04:34 PM
Ruger .22 SA - not a good show
by JHZR2 - 02/16/20 03:48 PM
engine maintenance Jaguar
by jssaab - 02/16/20 03:02 PM
New TSC clearance
by Greg L - 02/16/20 02:58 PM
FlightRT, 74Widebody, mmmmmnnn, jjrockbush, eamerritt
70721 Registered Users
37 registered members (BLND1, AdditionalD, Bailes1992, ArrestMeRedZ, carlprop, bbhero, 2 invisible), 1,150 guests, and 47 spiders.
Topics301,545
Posts5,197,721
Members70,721
Page 1 of 7 1 2 7
I need the best penetrating oil #810770 01/15/07 01:34 AM
M
Maximumcanon Offline OP
M
.......but not Penetro. I need something for removing rusted automotive exhaust parts but i pretty much need it by tomorrow. Sick of these mail order companies and the closest "rep" to me for Penetro is about 100 miles away. Anyhow, what is the best one that is sold in most local stores. Liquid wrench? I know WD-40 isnt a pen oil at all. Any out there better than Liquid Wrench?
Re: I need the best penetrating oil [Re: Maximumcanon] #810771 01/15/07 02:10 AM
W
Wrehch Offline
W
You might be able to find PB Blaster or Kroil at a local store. Both are good rust busters.
Another good trick for removing rusty exhaust bolts I learned from a old mechanic is to use canning wax. The kind of wax you can buy at the grocery store. Heat the part up a little with a small tourch, just hot enough to melt the wax. Apply the wax and watch it be drawn into the rust. This trick has worked for me where penetrating oils have failed. Might be worth a try and a box of canning wax is cheap.
Re: I need the best penetrating oil [Re: Wrehch] #810772 01/15/07 02:12 AM
M
M
thanks.
Re: I need the best penetrating oil [Re: Maximumcanon] #810773 01/15/07 03:40 AM
M
M
Tihnk PB Blaster will help a seized car lock? safe on auto paint?
Re: I need the best penetrating oil [Re: Maximumcanon] #810774 01/15/07 11:57 PM
R
rat Offline
R
Its kinda expensive and I think only new car dealers carry it, but Rost-off made by WURTH is very effective for locks.
2015 Focus SE hatch 5 speed manual
2003 Expedition 5.4
2018 Grand Caravan
2000 Honda CRV
2000 Buick Century
Re: I need the best penetrating oil [Re: Maximumcanon] #810775 01/17/07 07:18 AM
T
tony58 Offline
T
Re: I need the best penetrating oil [Re: tony58] #810776 02/02/07 01:02 AM
smthrj53 Offline
KROIL
Re: I need the best penetrating oil [Re: smthrj53] #810777 02/02/07 01:28 AM
04SpecV Offline
rustreaper
Re: I need the best penetrating oil [Re: 04SpecV] #810778 02/02/07 05:59 AM
B
Burner Offline
B
The wax trick.....never heard of it but it sounds like a fun idea to try!
Re: I need the best penetrating oil [Re: Burner] #810779 02/03/07 10:51 PM
smeltjr Offline
The wax trick is indeed effective. Before i hit any ruusted, and I mean rusted, bolt I hit it with Kroil or PB Blaster the night before. Then I heat it real well and pour or spit cold water on it while it is glowing hot. Then heat it again and use wax. Only thing that this did not work on wan an exhause bolt. At that point, it was getting a new one anyway and got out the angle grinder.
Re: I need the best penetrating oil [Re: smeltjr] #810780 02/08/07 07:52 AM
O
Oldsragtopguy Offline
O
93 Olds Cutlass Ragtop
3.4 DOHC 200 HP V-6
Re: I need the best penetrating oil [Re: Oldsragtopguy] #810781 04/23/07 04:36 AM
P
peterr Offline
P
I second the recommendation for PB Blaster. It is the best over the counter rust busting oil i have found
Re: I need the best penetrating oil [Re: peterr] #810782 04/27/07 06:01 AM
Crashbox Offline
I've used Kroil before and IMO it is very hard to beat. Loosened a power steering pulley when nothing else seemed to work...
I should know better than to try and add "Motor Oil" to an ENGINE...
Re: I need the best penetrating oil [Re: Maximumcanon] #810783 05/28/07 10:56 AM
T
Thingfish Offline
T
IMHO, KROIL. I ran a muffler shop for a long time and MANY times it was the only thing that saved parts like manifold studs from the cutting torch. And rarely did I have more than a few minutes to let penetrants work.
I have found nothing else close.
Re: I need the best penetrating oil [Re: Thingfish] #810784 05/31/07 04:41 AM
P
porcupine73 Offline
P
Kroil certainly does work extremely well. I've also used the wax trick with success, but I've heard you need real beeswax.
Page 1 of 7 1 2 7
