Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
120 registered members (apollo18, 928, 2012AccentSE, aquariuscsm, Anduril, ABomb369, 9 invisible), 2,279 guests, and 21 spiders.
Topics301,698
Posts5,200,852
Members70,759
Page 2 of 2 1 2
Re: 2009 corolla 1.8 [Re: wwillson] #5327131 01/19/20 02:23 PM
I
Imp4 Offline
I
Originally Posted by wwillson
Can we correlate longer OCIs to timing chain wear?
Yes please, go right ahead.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: 2009 corolla 1.8 [Re: Bettez88] #5327139 01/19/20 02:43 PM
JohnnyJohnson Offline
On my 2004 Corolla I used to do 3K change with conventional oil at 66K I switched to full synthetic. I run my OCI from April to October and then October back to April.
The miles very a little but seems to be in the 6400 to near 7200 mile range. Everything seems to be doing just fine. UOA has come back showing pretty good life still left in the samples I've sent in. It's specked for 5W-30 but currently I'm running 5W-20 PUP HM and several times have run 10W-30. The oil that is one sale is what I use. I am not a fan boy of any name brand of oil.
2004 Corolla 138781
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: 2009 corolla 1.8 [Re: Bettez88] #5327151 01/19/20 02:57 PM
A
atikovi Offline
A
Originally Posted by Bettez88
It seems like a waste to use full synthetic for 5k but I’m not sure
With synthetic under $3 a quart when on sale, how much cheaper can you find conventional?
Re: 2009 corolla 1.8 [Re: HangFire] #5327173 01/19/20 04:03 PM
CR94 Offline
Originally Posted by HangFire
... Supposedly the factory recommendation was 5K then later changed to 10K on my [2010] Corolla. Probably yours too. Toyota left the reminder at 5K because they want you in for tire rotations and checks.
That's all true. Their 10k recommendation is effectively conditioned on using synthetic oil, so I wouldn't recommend taking conventional oil that far.
The '07 version, which a couple of other posters have mentioned, was a different, older-design engine than 2009 and later.
2011 Toyota Prius now at 109K
Re: 2009 corolla 1.8 [Re: Bettez88] #5327197 01/19/20 04:45 PM
M
madeej11 Offline
M
No need for all of this 5k talk. That engine is really reliable and will run on anything you want give it. 8-10k on 5w30 syn and oem filter or for that matter any half decent oil filter. It's not complicated.
Re: 2009 corolla 1.8 [Re: Bettez88] #5327239 01/19/20 05:34 PM
slacktide_bitog Offline
Toyota says 5k on dino, 10k on synthetic smile
Sale prices and rebates can make synthetic oils priced the same as or even cheaper than dino
Re: 2009 corolla 1.8 [Re: Bettez88] #5327361 01/19/20 08:07 PM
E
Elkins45 Offline
E
My 2007 Corolla went 178k trouble-free miles on 5k conventional 5w-30 changes. AFAIK it’s still being driven daily by the new owner. I doubt the 09 engine is much different.
Re: 2009 corolla 1.8 [Re: slacktide_bitog] #5327585 01/20/20 07:50 AM
B
Bettez88 Offline OP
B
Thank you! I may still run a less expensive synthetic for 5k
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: 2009 corolla 1.8 [Re: Bettez88] #5327629 01/20/20 08:32 AM
T
Triple_Se7en Offline
T
The Owners Manual says 5K Dino and 10K Synthetic?
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: 2009 corolla 1.8 [Re: Triple_Se7en] #5327722 01/20/20 10:26 AM
B
Bettez88 Offline OP
B
No it states either 5w20 or 0w20 may be used. Doesn’t specify conventional or synthetic. But it says oil and filter change every 5000 miles
Re: 2009 corolla 1.8 [Re: Bettez88] #5327754 01/20/20 10:54 AM
CR94 Offline
Slightly later manuals for most Toyotas, including ones with that same engine, state 0W-20 should be used, but that 5W-20 may be used. They go on to say 5W-20 must be replaced within 5000 miles. To avoid confusing easily confused customers, the manual says nothing directly about synthetic vs. conventional, but they were aware that 0W-20 was nearly always synthetic, while 5W-20 was not necessarily. The maintenance manual, in contrast, specifically says conventional 5W-20 may be used, subject to the same restrictions; it says nothing about synthetic 5W-20. All that implies the answer to Triple_Seven's question is "yes."
Therefore, I'm using synthetic 5W-20 in mine, at intervals of roughly 8.5k, to be a little more conservative than their 10k suggestion.
Re: 2009 corolla 1.8 [Re: Bettez88] #5327926 01/20/20 02:14 PM
B
Bettez88 Offline OP
B
Toyota has these recommendations for synthetic oil:
Only Toyota vehicles in which 0w-20 synthetic oil is required (except for the 2TR-FE & 3UR-FBE Engines*) have been approved for extended oil change intervals of 10,000-miles/12-months. (However, you should continue to check the oil level regularly and top off if needed. That will help your engine get the full benefit of synthetic oil.)
Vehicles in which 0w-20 is an option to 5w-20 mineral oil, (or 5w-30), will continue to require 5,000-mile/6-month oil change intervals, even if 0w-20 oil is used.
In the case of vehicles with 10,000 mile oil change intervals, the 5,000 mile service interval has not been eliminated. The traditional 5,000 mile maintenance procedures (such as tire rotation) will continue to be required, and the fluid levels (such as brake fluid) will need to be checked and adjusted at this time.
If the vehicle operation meets the standard criteria for “Special Operating Conditions” such as: driving off-road, on dirt roads, towing a trailer, making repeated short trips under 32˚ F, or extensive idling; the engine oil must be replaced at 5,000 mile intervals, regardless of what type of oil is used.
*The 2TR-FE (4Runner / Tacoma) and the 3UR-FBE (Flex Fuel Tundra / Sequoia) are the exceptions to this new change interval program; these engines have not been approved for the 10,000 mile interval at this time. A 5,000-mile/6-month oil change interval is still required for these vehicles. Also, the Flex Fuel 3UR-FBE requires a 2,500 mile interval when operated on E85.
To recap, the decision to use synthetic isn’t black and white. You should take care to read and understand this choice prior to opting for it.
Re: 2009 corolla 1.8 [Re: Bettez88] #5327991 01/20/20 03:29 PM
W
willbur Offline
W
Originally Posted by Rolla07
The OCI is 5k miles (8k kms). My 07, Ive used 0w20, 5w20, 5w30, 5w40, 5w50. This engine will take whatever you give it. Ive alsorun conventional but mainly syn since like many of us, I seek out deals. A solid price for oil combined with mail in rebate comes out to the same or cheaper than conventional. Worst case a 5qt of Supertech syn can be had for 16$ or so. That price to me makes it a no brainer. Ive run my oil to 6200 miles using a syn oil and cheapo napa proselect and my oil analysis was excellent, could of gone longer. If I were you, run 6k miles and use the cheapest syn you can find. Even if u choose to go conventional, that engine will outlast the car.
Think it’s a waste to use the Oem filter too? I could run the ST 10358 and their 5w20 synthetic for 5 k and the filter would probably hold up well
Bettez-
You are obsessing about an 11 year old hooptie car. Anything will do.Geez
Page 2 of 2 1 2
