Toyota has these recommendations for synthetic oil:
Only Toyota vehicles in which 0w-20 synthetic oil is required (except for the 2TR-FE & 3UR-FBE Engines*) have been approved for extended oil change intervals of 10,000-miles/12-months. (However, you should continue to check the oil level regularly and top off if needed. That will help your engine get the full benefit of synthetic oil.)
Vehicles in which 0w-20 is an option to 5w-20 mineral oil, (or 5w30), will continue to require 5,000-mile/6-month oil change intervals, even if 0w-20 oil is used.
In the case of vehicles with 10,000 mile oil change intervals, the 5,000 mile service interval has not been eliminated. The traditional 5,000 mile maintenance procedures (such as tire rotation) will continue to be required, and the fluid levels (such as brake fluid) will need to be checked and adjusted at this time.
If the vehicle operation meets the standard criteria for "Special Operating Conditions" such as: driving off-road, on dirt roads, towing a trailer, making repeated short trips under 32Ëš F, or extensive idling; the engine oil must be replaced at 5,000 mile intervals, regardless of what type of oil is used.
*The 2TR-FE (4Runner / Tacoma) and the 3UR-FBE (Flex Fuel Tundra / Sequoia) are the exceptions to this new change interval program; these engines have not been approved for the 10,000 mile interval at this time. A 5,000-mile/6-month oil change interval is still required for these vehicles. Also, the Flex Fuel 3UR-FBE requires a 2,500 mile interval when operated on E85.
To recap, the decision to use synthetic isn't black and white. You should take care to read and understand this choice prior to opting for it.
