Old Vise info
by A310 - 11/16/19 10:18 PM
2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
Sinopec 75w-90 Synthetic
by jdw1222 - 11/16/19 12:51 PM
Honda Oil Filter
by miden851 - 11/16/19 12:28 PM
VOA for QSAD 10w-40?
by natas - 11/16/19 12:02 PM
billad67, aka_Claus, Diverdown, natas, matt3540
69886 Registered Users
74 registered members (69GTX, 77GrandPrix, 92saturnsl2, 2015_PSD, A310, 8 invisible), 1,550 guests, and 21 spiders.
Topics297,521
Posts5,117,341
Members69,886
Most Online3,589
Nov 2nd, 2019
Installing your own winter tires #5239236 10/14/19 09:43 AM
Snagglefoot Online Content OP
OP Online Content
For snow areas only. Alabama boys need not apply. Do you install your own winter tires?
It’s a task I don’t mind.
I use a floor jack, jack stand, wheel blocks, corded electric impact wrench and torque wrench.
When I have the wheel off, I grease any suspension fittings (that have zerks) near the hub, inspect the brake pads, and CV boots, and give the frame a shot of Krown rust preventer. I then check and adjust the air pressure.
I prefer it over a shop because their employees typically go ape with the impact wrench when tightening down the nuts. Just don’t get a hernia when dealing with trucks tires. smile
If you want the job done right......do it yourself.
Re: Installing your own winter tires [Re: Snagglefoot] #5239241 10/14/19 09:49 AM
B
benhen77 Offline
B
I did it by hand for a while on 3 vehicles. Have a 1/2 inch cordless impact this year, so I'm actually looking forward to it. For me, it's just as much work to load up the tires and run them out somewhere as it is to just swap em out myself.
2012 Kia Forte EX 2.0 I4 6AT 49k- Valvoline Synpower 5w20
1994 BMW 530i, 5MT 201k M1/Castrol 0w40
2009 Honda Accord 2.4 I4, 5AT, 178k- RP 0w20
2004 BMW X5 4.4l 239k- M1 0W40 FS
Re: Installing your own winter tires [Re: Snagglefoot] #5239253 10/14/19 10:06 AM
P
Pew Offline
P
The evo I did. The focus I'll just bring it into the dealer and they do it as part of the 'the works' with the oil change and tire rotation.
Re: Installing your own winter tires [Re: Snagglefoot] #5239258 10/14/19 10:12 AM
H
HangFire Offline
H
Every late Fall and Spring. With air tools its not too bad. Usually try to schedule in something with it- brake bleed, check/lube brakes, of course inspect tie rod ends and a little Fluid Film on anything that is, or might rust.
Various musings: http://hangfire.net
Re: Installing your own winter tires [Re: Snagglefoot] #5239259 10/14/19 10:13 AM
L
lyle Offline
L
Been swapping tires over myself twice a year on my own car for almost 40 years. I used to break the lug nuts loose with a breaker bar, but since I got a cordless impact, it's much easier. When I picked up a wife 30 years ago, I had to swap her tires over twice a year also, and kids cars for over 2 decades...
It's peace-of-mind knowing that something is done right, and not having some random guy torque your nuts to insane ft/lb numbers is most reassuring.
Re: Installing your own winter tires [Re: Snagglefoot] #5239268 10/14/19 10:18 AM
B
benjayman227 Offline
B
Always do my own. Even when all I had was a scissor jack and a cinder block. I have major trust issues with shops. I must be bad at picking them.
The title of the post initially made me think mounting/balancing, not just wheel swapping. Which I also have done. My grandfather has a changer bolted to the floor and a static balancer. Although with these new-fangled 20" alloy wheels and TPMS, those tools have been recently gathering dust...
Re: Installing your own winter tires [Re: Snagglefoot] #5239281 10/14/19 10:30 AM
Q
Quattro Pete Offline
Q
I'm assuming you mean winter tires that are already mounted on winter wheels so there is no need for remount/rebalance. If so, yeah, I swap those out on my 530i.
On wife's Q5, I let the local shop do the swap as I don't want to break my back.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Installing your own winter tires [Re: Snagglefoot] #5239303 10/14/19 10:51 AM
W
WyrTwister Offline
W
I too thought the OP was swapping tires on wheels . Seems he / she is talking about swapping wheel / tire units .
Wyr
God bless
Re: Installing your own winter tires [Re: benhen77] #5239304 10/14/19 10:53 AM
P
pktrkt Offline
P
Totally agree. Easier to just do it right, at the right time (around here = mid November).
2010 Honda Fit Sport - QSAD 5W20/Bosch 3323
2013 Mazda5 GS - Castrol Edge 0W20/Pennzoil P-21
Re: Installing your own winter tires [Re: WyrTwister] #5239334 10/14/19 11:28 AM
OP Online Content
Yes, most folks who have winter tires up here, keep them on separate rims. For the apartment dwellers, a lot of the tire shops will store your summer / winter sets in a warehouse for a fee. For the folks that have larger garage, we buy a tire rack and keep them in the corner of the garage. smile
Re: Installing your own winter tires [Re: Snagglefoot] #5239349 10/14/19 11:39 AM
X
xxch4osxx Online Content
Online Content
X
I swap the winters on rims with the summer wheels every fall on the girlfriend's car. I'm not paying a shop $35 per tire to swap the rubber out twice a year.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: Installing your own winter tires [Re: Snagglefoot] #5239397 10/14/19 12:46 PM
spavel6 Offline
It's way faster to do it at home than go to the tire store, sit at the tire store, interact with tire store employees, get upsold on some BS tire store service, get home to find out that the tire store messed something up, rinse, repeat.
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: Installing your own winter tires [Re: Snagglefoot] #5239415 10/14/19 01:06 PM
DriveHard Offline
yup!
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Installing your own winter tires [Re: Snagglefoot] #5239454 10/14/19 01:52 PM
E
ecotourist Offline
E
I used to do that. The big advantage to doing it yourself is you can wait until it actually snows to do the changeover. Otherwise you'd have to get it done weeks ahead of time. The tire shops get so busy with the first snow that you'll wait days for an appointment.
But now that I live on the left hand coast, my snow tires simply rest easy in the garage. I could put them on, but I don't really need them. We hardly ever get snow, and it only lasts a day or two if we do. And I don't have to go anywhere that can't wait a couple of days.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Installing your own winter tires [Re: Snagglefoot] #5239461 10/14/19 02:10 PM
B
benhen77 Offline
B
Or if you're like I was a few years ago, you drag 4 wheels and tires up to the third floor and stick them in the closet of your 1 BR apartment. LOL
