As noted Champ Labs makes different tier filters, the lowest 'Champ Labs labeled' (on RA) filters would be similar to or same as current Super Tech line, value/jobber. Majority of those applications are ecore filters using a combo valve. As noted the P-T is Wix's lowest tier, jobber tier filter recommended for 3-5k miles by Wix. They have Wix type construction and some use combo valves.
Looking at your signature applications with the exception of the 09 they are GM with block bypass, combo valve not applicable. They would be ecores.
So given the choice between two listed only, because of construction preference I'd go with the ProTec. In reality if run 3-5k miles, likely not to make much difference.
