2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
2020 Kia Forte Engine
by artbuc - 01/24/20 03:27 PM
Torn filter that's NOT a motorcraft.
by mpgo4th - 01/24/20 03:22 PM
K&N PS-1008 $3.36
by jayjr1105 - 01/24/20 03:14 PM
Forum notifications?
by jayjr1105 - 01/24/20 02:50 PM
Thinking about transmission cooler for Honda
by jayjr1105 - 01/24/20 02:26 PM
Goodyear Assurance Comfortred Touring
by Keystone - 01/24/20 02:03 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
65 registered members (ArrestMeRedZ, aleneros, Analyzer, 4WD, alchargo, 6 invisible), 1,962 guests, and 18 spiders.
Topics300,513
Posts5,177,551
Members70,518
Rear Wheel Bearing Replacement? #5138848 06/19/19 09:37 PM
G
Gebo Offline OP
G
Gotta replace the rear wheel bearing on my 2005 LS430. Which brand could I use and be just as good as Toyota? I am thinking either Timken or Koyo.
The Timken uses a Koyo bearing.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
PP HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5138886 06/19/19 10:40 PM
clinebarger Online Content
Online Content
Koyo would be OE, Koyo owns/bought the Timken & Torrington needle roller bearing divisions 10 years back.
2001 Chevy Camaro L92/4L80E
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5138938 06/20/19 04:05 AM
M
MoneyJohn Offline
M
Not too sure of Lexus, but I changed one for our 2015 Forester. The mechanic said SKF is next best to OEM.
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5138989 06/20/19 05:53 AM
A
atikovi Offline
A
You need to find out where the bearing is made. Some Timken are made in China and should be avoided if you plan on keeping the car more than a year or two.
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139102 06/20/19 08:48 AM
ls1mike Offline
What i have found with any new bearing is they are hit and miss. There were some pretty big discussions about on my Facebook car sites and it seems that it affects all makes.
When we did my buddies Camry, the first one we replaced it with failed quickly, less than 3000 miles. It was a Timken unit.
When I did the front one on my 05 Grand Prix, I had a similar problem. Second one lasted a long time. As I recall it was an SKF.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139117 06/20/19 09:04 AM
G
Gebo Offline OP
G
Just talked with the Lexus mechanic that does my more complicated work and he said to use KOYO as they make the bearings for Lexus.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
PP HM 10W-30
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139184 06/20/19 11:00 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Many of the big-name bearing manufacturers have two lines of bearings. One is their OEM line. The other is their replacement "jobber" line, which costs considerably less.
Re: Rear Wheel Bearing Replacement? [Re: MoneyJohn] #5139276 06/20/19 01:07 PM
SubieRubyRoo Offline
IIRC, NTN is OEM. In my opinion, I always try to use OEM on Subaru bearings. On the 2008-earlier Subies (non-Legacy/Outback), using a non-NTN bearing will usually have you changing it again within a year or less for bearing noise.
IMHO, bearings are inexpensive enough to just go with the OEM supplier.
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139287 06/20/19 01:19 PM
G
Gebo Offline OP
G
Just the bearing wouldn’t be bad but I’m buying the entire assembly. $215-$290 for s “brand name.”
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
PP HM 10W-30
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139344 06/20/19 02:57 PM
Silverado12 Offline
FWIW my 2018 Mustang got sideswiped by an 18 wheeler and the rear bearing made noise when I got it back from the body shop. I did the work myself and used a Motorcraft hub/bearing as a replacement. I couldn't tell anything was wrong with the damaged bearing by spinning it by hand once it was off the car. It seems they are made to pretty tight tolerances/clearances as to where a little wear/damage will make noise. Highly recommend OEM parts for this application.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139373 06/20/19 03:25 PM
M
mclasser Offline
M
I put a Timken rear hub bearing assembly on my Accord a few years back and it's still going strong. Made in the USA with a NTN bearing (OEM one was NTN Japan). I lucked out getting it on clearance at AZ for like $30.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139454 06/20/19 04:59 PM
J
JTK Offline
J
Unless you specify and can wait for one, you're at the mercy of what the shop you choose to do the work for you can get quickly, from where they normally get their parts delivery from. If it's from Napa, etc, I don't think you really know who made the bearing and the quality of it.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139511 06/20/19 05:55 PM
G
Gebo Offline OP
G
I ordered a KOYO from Amazon
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
PP HM 10W-30
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139520 06/20/19 06:04 PM
H
hallstevenson Online Content
Online Content
H
Dang, that's steep, even for a bearing assembly. Rockauto has a Timken for $177 and a Moog for $190. With RA's shipping, Amazon's base price is a bit higher but once shipping is added in, they're probably close.
How are you getting such a wide variation in price from $215 up to $290 ?
Re: Rear Wheel Bearing Replacement? [Re: Gebo] #5139661 06/20/19 08:36 PM
Y
Y_K Offline
Y
You could look up Mr T part number on partsouq site. I buy a lot from them. Even with shipping from Dubai, some items are cheaper than Rock's and arrive quicker.
Interestingly enough, just as an example, genuine lug nuts from the local dealer had Made in USA on them, and partsouq shipped me Made in Japan cheaper. Did not have a pleasure fixing rear ones, but the front ones were either Timken or Koyo from Toyota. As others said, they have different lines and different QA. It is impossible to buy a real, genuine Lexus OE part, as they are created by their QA at the assembly factory from Toyota parts. We had a few interesting anecdotes with the same part failing in Landcruiser UJ100 and working fine in a Lexus LX470 line.
