98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
34 registered members (crainholio, Chesterr, clinebarger, chemman, A_Spruce, 4 invisible), 824 guests, and 19 spiders.
Topics292,010
Posts5,015,187
Members68,692
Most Online2,967
Mar 10th, 2019
Waterpump - OEM or Aftermarket #5120618
05/30/19 07:46 PM
05/30/19 07:46 PM
Florida
Fitz98 Online content OP
Fitz98  Online Content OP
Florida
98 Expedition 5.4 4x4
Anyone know how the Motorcraft OEM water pumps hold up compared to aftermarket?
I have mine off currently, works fine for now, but thinking since I have it off, I might as well replace it, since I don't know the history of this one (Used engine replacement a couple years back). Also had a problem with transmission fluid in my coolant, so don't know if there are any internal seals that may have been compromised, so I would rather replace than be sorry later.
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5120622
05/30/19 07:49 PM
05/30/19 07:49 PM
Apple Valley, California
Chris142 Offline
Chris142  Offline
I just put one on a customers truck. Made in China just like the aftermarket ones.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5120624
05/30/19 07:51 PM
05/30/19 07:51 PM
In the Garage...
ls1mike Offline
ls1mike  Offline
In the Garage...
Not Motorcraft, but when I did the water pump on my truck I used an aftermarket one. has been fine even when towing in summer heat.
I think they have water pumps figured out pretty good.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5120650
05/30/19 08:09 PM
05/30/19 08:09 PM
USA
slacktide_bitog Offline
USA
Get the Motorcraft pump smile
It is made in Canada Canada
Re: Waterpump - OEM or Aftermarket [Re: slacktide_bitog] #5120667
05/30/19 08:31 PM
05/30/19 08:31 PM
Chris142 Offline
Chris142  Offline
The one I just put on yesterday was made in china.
Re: Waterpump - OEM or Aftermarket [Re: Chris142] #5120743
05/30/19 09:56 PM
05/30/19 09:56 PM
USA
USA
I looked up the specific part number for the OP's 98 Expedition 5.4L
PW-423
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5120793
05/30/19 11:18 PM
05/30/19 11:18 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Only about $35 plus shipping at Rock Auto.
If you want the job done right......do it yourself.
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5120934
05/31/19 06:30 AM
05/31/19 06:30 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
As long as its not a white box part or Gates WP you will probably be ok.
yup
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5121032
05/31/19 08:16 AM
05/31/19 08:16 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Transmission fluid in coolant ? Can not think of any way that is related to the water pump ?
Most / all cars with automatic transmissions have a cooler for the AT fluid . This often is a " device " in the radiator , to transfer excess heat from the fluid to the coolant . There may be a leak there . ( With 2 lines from the AT to the radiator . )
If that is what is happening , I question whether the radiator can be repaired . Either replace the radiator or buy an external ATF cooler to mount in front of the radiator & re-plumb the lines from the AT , to the new external cooler .
But , if you have ATF in the coolant , check the transmission to be sure you do not also have coolant in the ATF . A messed up transmission is much more expensive than the radiator .
To me , this potentially is a MUCH larger issue than your original question .
Wyr
God bless
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5121042
05/31/19 08:26 AM
05/31/19 08:26 AM
Albany, NY
ford46guy Offline
ford46guy  Offline
Albany, NY
You need a radiator too. Do not drive like that, and do a total trans flush by changing the filter and draining the torque converter.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5121045
05/31/19 08:30 AM
05/31/19 08:30 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
My late father in law bought a used tractor that had a Yanmar engine it . Hole in the block .
FIL was a retired mechanic . He rounded up the parts and performed the repair . This left the engine with a hole in the block .
Brother in lay ( his son ) is / was a welder . He found a piece of cast iron close to the desired dimensions , ground it to fit and welded it in place , to fill the hole .
FIL said it still seeped oil , just a little bit , but nothing major . Just keep an eye on the oil level .
Wyr
God bless
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5121214
05/31/19 11:30 AM
05/31/19 11:30 AM
California
nthach Offline
nthach  Offline
California
OEM or Motorcraft. Even if they are made in China, Ford is still specifying a Japanese-supplied bearing.
Although, I will say this - I've installed a Chinese pump on a friend's Explorer and it's still working. The gasket is leaking, kinda my fault but it's a paper gasket as well.
Re: Waterpump - OEM or Aftermarket [Re: WyrTwister] #5121219
05/31/19 11:34 AM
05/31/19 11:34 AM
Florida
Florida
I have already dealt with that part is a separate forum post. Now my objective is to replace anything in the cooling system with seals that have been exposed to the transmission fluid in the coolant.
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5121522
05/31/19 04:52 PM
05/31/19 04:52 PM
Florida
Florida
I went with the dealer OEM. I am not sure what pump I took out. Could have been changed by someone else in the past.
Here is a side by side comparison.
OEM has a ring welded to the fins and has 6 fins whereas the other one has no ring and 7 fins.
OEM fins are 9 thousandths longer than other one I took out.
The OEM fins are about 1/4" less in overall diameter
Gauge thickness of the fins is about the same.
The one I took out also has 2 small pieces of casting off of 2 of the bolt holes, OEM does not have that.
This is a replacement motor, so not sure what it came out of, if the water pump is different for the motor I have in there now, or if the one I took out is an aftermarket water pump.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Do you think these are the differences between OEM and aftermarket or is it possible the motor I have requires a different pump?
Re: Waterpump - OEM or Aftermarket [Re: Fitz98] #5121541
05/31/19 05:12 PM
05/31/19 05:12 PM
Florida
Florida
Just answered my own question, bolt holes don't line up, now the question is how do I identify what motor I have to find the matching pump, or how to identify the pump I took out to get the right one.
[Linked Image]
