ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
Wear Metal Max?
by tsm750. 07/16/19 05:54 PM
Harbor Freight 25% off Thurs - Sunday
by JC1. 07/16/19 05:52 PM
80% Furnace exhaust silencer?
by PandaBear. 07/16/19 05:10 PM
Pennzoil Ultra on Sale
by Nyati. 07/16/19 04:39 PM
Not All Mid-Grade Blended At the Pump
by RayCJ. 07/16/19 04:30 PM
Determining if car battery has much life left
by paulri. 07/16/19 02:47 PM
kohker oil recomendation
by 1978elcamino. 07/16/19 02:44 PM
Rear Diff Seal Leak?
by Pike51. 07/16/19 02:31 PM
Using synthetic to clean a crankcase
by NavyVet88. 07/16/19 02:26 PM
Next Project: 1968 Cub Cadet Model 72
by Phishin. 07/16/19 02:14 PM
Mother's CMX
by rooflessVW. 07/16/19 01:54 PM
MBhuntington, captainfloss, Lyndol, Belczek, Bronco628
68681 Registered Users
104 registered members (69GTX, 4WD, AandPDan, 9050lx, AdditiveOCD, 2010Civic, 6 invisible), 2,118 guests, and 23 spiders.
Topics291,966
Posts5,014,181
Members68,681
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Hyundai new car oil recommendation. #5120776
05/30/19 10:56 PM
05/30/19 10:56 PM
Sg johor
bernau Offline OP
bernau  Offline OP
Sg johor
Hi im in asia where its 27 to 34 degrees celcius all year round. according to the manual, what can i use?
I got api sn oil and acea a3 b4. What oil grade should i use? [Linked Image]
[Linked Image]
Engine is a 1.6 na port injected engine.
Re: Hyundai new car oil recommendation. [Re: bernau] #5120786
05/30/19 11:10 PM
05/30/19 11:10 PM
America's Dairyland
LotI Online sleepy
LotI  Online Sleepy
America's Dairyland
According to the manual, anything you want. 5w-30 looks preferred in warmer climes.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Hyundai new car oil recommendation. [Re: LotI] #5120792
05/30/19 11:17 PM
05/30/19 11:17 PM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Not quite anything. I don't see bacon grease listed..😂
Re: Hyundai new car oil recommendation. [Re: LotI] #5120795
05/30/19 11:19 PM
05/30/19 11:19 PM
Sg johor
bernau Offline OP
bernau  Offline OP
Sg johor
What about the chart i attached? It looks like 15w-40 or 20w-50 is feasible too. Can anyone confirm this?
Normally do we follow the recommended oil or so long as the specs are met its good enough?
Re: Hyundai new car oil recommendation. [Re: Mad_Hatter] #5120797
05/30/19 11:28 PM
05/30/19 11:28 PM
PimTac Offline
PimTac  Offline
Another ♻️
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Hyundai new car oil recommendation. [Re: bernau] #5120802
05/30/19 11:38 PM
05/30/19 11:38 PM
Lima, Ohio, USA
earlyre Online sleepy
earlyre  Online Sleepy
Lima, Ohio, USA
it looks like you could use any of the listed grades, but they are recommending 5w30 for Better Fuel Economy.
Mine:
13 Ford C-MAX hybrid: MC 5w20, & FL910s (in theory)
Re: Hyundai new car oil recommendation. [Re: bernau] #5120818
05/31/19 12:20 AM
05/31/19 12:20 AM
Nebraska
Jesse_NE Offline
Jesse_NE  Offline
Nebraska
Considering your climate's temperature range, feel free to run 15w40 or 20w50, as long as it meets manufacturer's specifications. Just be advised that with thicker oils, you will likely experience a mild fuel economy trade-off over running a lighter engine oil.
Re: Hyundai new car oil recommendation. [Re: bernau] #5120823
05/31/19 12:38 AM
05/31/19 12:38 AM
Yellowbrick Rd(KS)SemiRetired
Marco620 Offline
Marco620  Offline
10w30
15' Civic 1.8 i-vtec 254,000 mi Redline 5/0w20, BP transmax cvt fluid & Archoil9100
Tornado Chaser Extraordinar!
Son of a Navy Corpsman. Support vets!
Re: Hyundai new car oil recommendation. [Re: bernau] #5120824
05/31/19 12:38 AM
05/31/19 12:38 AM
Far East Side
DoubleNickels Offline
Far East Side
You may use any oil weight on the chart, because your local temperature is not extremely hot or cold. Be sure that you follow the ACEA spec.
From what I've seen, 5W20 weight will provide adequate lubrication and protection, and allow for better mileage. 5W-20 weight runs in most small cars, and even light duty trucks, across the USA.
You could try all of those motor oil weights, and report back with your progress. Chart everything. Give us as much raw data as possible.
Re: Hyundai new car oil recommendation. [Re: bernau] #5120856
05/31/19 02:04 AM
05/31/19 02:04 AM
WA
OilUzer Offline
OilUzer  Offline
WA
If you mention -50 or even -40 in US for small Hyundai's (especially MPI? I assume it's port injected and not DI) , thinies will send you to jail LOL
Re: Hyundai new car oil recommendation. [Re: bernau] #5120862
05/31/19 02:23 AM
05/31/19 02:23 AM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
If I were you I'd use 10w30 all year
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Hyundai new car oil recommendation. [Re: bernau] #5120866
05/31/19 02:56 AM
05/31/19 02:56 AM
T-County, Ohio
AnthemBassMan Offline
T-County, Ohio
I use 5w30 in my 2017 Elantra 2.0L year round, but have been toying with the idea of running 10w30.
L8R,
Matt
2010 Chrysler Sebring Touring 185k miles
Harvest King 5w20 synthetic/Prime Guard filter
2017 Hyundai Elantra SE 35k miles
Quaker State Ultimate Durability 5w30/Fram Ultra filter
Re: Hyundai new car oil recommendation. [Re: bernau] #5120868
05/31/19 03:02 AM
05/31/19 03:02 AM
Canada
Oleo Offline
Oleo  Offline
Canada
Based on availability and cost, you could go for the Shell Helix Ultra 5w40. Those are often on sale there for a decent price.
Re: Hyundai new car oil recommendation. [Re: bernau] #5120874
05/31/19 03:42 AM
05/31/19 03:42 AM
Sg johor
bernau Offline OP
bernau  Offline OP
Sg johor
Thanks, the after sales service person was saying if you use other than shell helix 5w 30, your warranty will be voided.
I have a rather huge stash of rotella and other oils that I hope I can eventually use.
Re: Hyundai new car oil recommendation. [Re: bernau] #5120881
05/31/19 04:40 AM
05/31/19 04:40 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
10w-30 would be a safe bet.
2003 Mercury Grand Marquis.
2007 Hyundai Santa Fe AWD.
2005 Toyota Avalon XLS
2006 Kawasaki Vulcan 900 LT.
Page 1 of 3 1 2 3
