I figure since there's been talk about lithium batteries, maybe someone knew more about these toll transponder batteries. I've been using California's FasTrak system for over a decade, but it always annoyed me that if the battery is depleted the only solution is to return it and get a replacement with a fresh battery. As far as I can tell they actually replace the batteries and reissue old transponders. I had a replacement that looked a bit discolored and scratched, but it worked fine.
I heard they used "lithium" batteries and had a nominal 5 year life, although it obviously will vary. This is kind of a tough environment since it can get really hot inside a car, where at minimum it will reduce battery life and worst case will leak. But for a rated 5 year life I thought it had to be something like a CR2 or CR123. I finally had a look at what's in an earlier Bay Area FasTrak transponder, and it's a Panasonic BR2477A 3V lithium cell. Apparently a tabbed cell that's bigger than a coin cell but smaller than a cylindrical cell. About 1000 mAh and designed for higher temperature operation/storage.
Anyone played around with one of these things before? I suppose most people won't because there's a deposit or at least they'll make the customer pay for one that's damaged. But it occurred to me that Costco sells them locally with a discount compared to the toll value and no deposit, so someone could buy one of them, use up the toll value, then disassemble.
I know of one version of these in California that had a battery hatch (with test button) and is user serviceable with a CR2450 battery. I mean - that means the customer is expected to pay for it compared to a free replacement, but it's a big pain to either mail one in and wait for the replacement or go to a service center.
