Originally Posted by Onetor
Nothing listed for XG9688, no specs. No specs for XG2. The Ultra isn't listed for XG2?
Not sure where you're looking but the XG9688 and XG2 spec's are right here.
XG9688 spec's.
XG2 spec's.
That is a different page than the OP posted. No burst strength et al. Motorking has provided further specs than what is provided on that page. Go to the webpage the OP provided and type in those exact model #s.
Not sure what you mean here.
XG12060 specs per OPs link:
Height 3.33
Inside Diameter 22mm x 1.5
Outside Diameter 3.00
Anti-Drainback Valve YES
By-Pass Valve Setting 19-25 PSI
Turning Specification 3/4 Turn after gasket contact
Base Gasket I.D. 2.45
Base Gasket O.D. 2.75
Base Gasket Thickness .196
XG9688 specs per my link:
Height 3.08
Inside Diameter 20mmx1.5mm Th'd
Outside Diameter 3.02
By-Pass Valve Setting 9-15
Style 1
Base Gasket I.D. 2.13
Base Gasket O.D. 2.42
Base Gasket Thickness 0.2
XG2 specs per my link:
Height 3.984
Inside Diameter 22mmx1.5mm Th'd
Outside Diameter 3.656
By-Pass Valve Setting 12
Style 1
Turning Specification 3/4-1
Base Gasket I.D. 2.422
Base Gasket O.D. 2.813
Base Gasket Thickness 0.203
No mention of burst strength anywhere on the OPs link that I could find...
When I went to the webpage the OP provided and typed in those numbers in the search (just like you said), out popped the information you see above.
