Looked at a house this weekend, liked it, ran into a question.
I think the land might have some water issues. It has been raining so finding a marshy spot away from the house was not surprising (like 100' away)--someone put in a drainage pipe so I'm thinking it's a known issue. Closer to the house though someone planted a nice weeping willow. I forget but probably 25 feet away from house. Wife took one look and said that meant lots of water present. So I'm thinking it may have been planted to so as to dry up the land next to the house. I do see a nice root headed towards house. Which would be an automatic fail I'd think except that there is no basement. Crawlspace of some sort that I was unable to access, with some portion of the house on posts.
The house is 80+ years old, septic is on the opposite side of the willow (and pumps up to a much further away leech field). Unsure where the geothermal field is but I'm guessing a willow isn't going impact that (?). There is a vapor barrier under the house (recently installed) but of course I couldn't inspect that, nor where the pipes go into the ground.
What should I be thinking here? No basement, possible water nearby, geothermal, ...? I'm used to basements where you can quickly see settle, shift, crack, etc. I'm not the first person to look at this and while I didn't see the inspection report the listing agent brought up other issues--had an inspector noticed what I did, the listing agent would have told me. Should have anyhow.
At the moment this is not someplace we are seriously considering, but it is something we would if our house sold.
