Originally Posted By: irv
I just tried ours after reading this thread and another one and my wife telling me it squeaked on her yesterday when she went to use it.
I also noticed this and it's quite pronounced. I/we did try it when we bought back in November but that was likely the last time. It squeaks about 1/2 to 3/4's the way back/open and squeaks in the same spot when it's closing.
This is the first ever vehicle with one so I know absolutely nothing about them but could it possibly be just dirt/crud up in there on the track or something else? Also, what sort of mtce do these require? The car is 2017 with around 24,000 kms on it. We purchased it used with around 20,000 kms on it.
I would appreciate any info about this issue and what all I need to do as far as mtce goes.
Thanks.
The owners manual probably tells you how to lubricate it, and the intervals. I'd do that and if it still squeaks, you still have a warranty, right?
There isn't a lot of info there but like it reads here, hopefully it is just dirt/debris?
Dirt and debris may collect on the
sunroof seal or in the track. This
could cause an issue with sunroof
operation or noise. It could also plug
the water drainage system.
Periodically open the sunroof and
remove any obstacles or loose
debris. Wipe the sunroof seal and
roof sealing area using a clean
cloth, mild soap, and water. Do not
remove grease from the sunroof.
If water is seen dripping into the
water drainage system, this is
normal
I'll have a look tomorrow and report back what I find and hopefully its good news.
Thanks.
I tried a few times today but I could not make it squeak like it did yesterday. Must have just been a piece of dirt/crud on the track or something similar?
Everything looked good up there. Lots of grease remaining from the factory and overall, things were pretty clean.
