Originally Posted By: Wolfie
...Can one generalize which oil is best based on summing up the total anti wear additives? What's a good way to find the best oil using this data. What would be the best mass market oil?
MACTgarage.com oil test data
Very cool chart.
1. Can one generalize which oil is best? No
2. What is the best oil using this data? There is no way to know which oil is best using the "data"
Summary,
The data, interesting but all its showing you are some properties of the oil and showing you a small handful of elements that the oils contain.
Also what does one mean by best? Best long lasting oil? Best low temperature oil? Best oil at preventing wear?
No oil does everything.
For me much of this stuff means nothing to me anymore. All oils of the same API are equal at preventing wear until its proven otherwise, even then, when someone tries to show that using a test, the test gets trashed.
So, bottom line, buy what you feel good about but if you change your oil on time or before the change is due, there is no way, at any price, to know which oil will be the best at preventing wear.
Modern oils are all pretty darn good and the marketing machines of big oil companies will be the deciding factor of what oil you choose.
No matter what, change on time, any oil of the correct API and your engine will most likely last longer then the vehicle itself and if it doesnt it was a manufacturing defect not an oil defect that leads to failure.
Motor Oil is a commodity now, much of what you buy base oil and the additive packages are produced by a handful of companies, much like the gasoline you purchase or any other thing in life, like your TV at home.
True they are produced to specs dictated by the companies themselves but no way to know what is best.
Remember, the absolute positively, most perfect anti-ware motor oil is the ACTUAL OIL ITSELF, not the additives. The "anti wear additives" added to the motor oil is to help prevent engine wear in engines with less then robust lubrication systems or times the oil has not reached the lubrication area during start up.
You maybe interested to note, AIRCRAFT PISTON motor oils to not contain the additives that automotive motor oils contain, from the same companies no less, why? Because the additives are actually metals and soft metals and these metals in the oil end up as deposits on the pistons, increase wear and engine failure.
Here is an older UOA on Aeroshell 15/50 oil
Anyway, again, just saying its about the oil, not what is in it and the only way we know it is any good is that it passes API.
