Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
110 registered members (Andy636, anndel, addyguy, aquariuscsm, 28oz, AandPDan, 9 invisible), 2,207 guests, and 52 spiders.
Topics296,731
Posts4,957,830
Members66,960
Most Online2,577
Jan 14th, 2019
Aftermarket wheel lug torque #4723588
04/11/18 11:22 AM
04/11/18 11:22 AM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
Bought some MB wheels that look like this for the cars summer tires. Assuming its alloy. Does the wheel lug torque of the oem steelies change when putting these on? 80 ft/lbs is what they call for normally. Am I right in alloy usually has lower torque?
'13 Toyota Tundra 5.7-Idemitsu
'08 Hyundai Elantra-Mobil 1
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
�01 Kawasaki KDX 220r
Re: Aftermarket wheel lug torque [Re: pda1122] #4723590
04/11/18 11:24 AM
04/11/18 11:24 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I just was looking at those wheels on DT. Did you get the install kit for $40 or so which is just wheel lugs?
Re: Aftermarket wheel lug torque [Re: pda1122] #4723595
04/11/18 11:27 AM
04/11/18 11:27 AM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
Yes I got wheel lugs and centric rings. All the lugs now use a key thats 19mm. Also came with 4 extra wheel lugs
Re: Aftermarket wheel lug torque [Re: pda1122] #4723598
04/11/18 11:30 AM
04/11/18 11:30 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Sweet, if you can post pics when you have them mounted that would be great to see. thumbsup
Re: Aftermarket wheel lug torque [Re: pda1122] #4723605
04/11/18 11:35 AM
04/11/18 11:35 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
With aftermarket wheels on small to midsize cars I use 110nm as a default and 140nm on large cars, recheck after 100km/miles
Re: Aftermarket wheel lug torque [Re: pda1122] #4723610
04/11/18 11:39 AM
04/11/18 11:39 AM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
Re: Aftermarket wheel lug torque [Re: pda1122] #4723614
04/11/18 11:44 AM
04/11/18 11:44 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Looks great and better than I thought they would.
Re: Aftermarket wheel lug torque [Re: pda1122] #4723636
04/11/18 12:01 PM
04/11/18 12:01 PM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
Thanks. Def needs a wash/wax
Re: Aftermarket wheel lug torque [Re: pda1122] #4723820
04/11/18 03:05 PM
04/11/18 03:05 PM
Seattle, WA
SnowmanCO Offline
SnowmanCO  Offline
Seattle, WA
Are the lug nuts similar to the OEM ones? If so, the torque requirement would be the same. Torque specs are based on the lug nut type and thread pattern/size. It has nothing to do with the wheel metallurgy. It has to do with getting the threads to "stretch". http://www.cpgnation.com/how-to-measure-bolt-stretch-for-proper-torque/
16 F150 5.0-QS UD 5w20,MtCrft FL500S
10 Merc C300-Mob 1 0w40,MANN H U7 18/5X
08 Maz3S 2.3-Cast Syn 5w30,Wix 57203XP
17JD D160-Cast Syn 0w30,MtCrft FL400S
Re: Aftermarket wheel lug torque [Re: pda1122] #4723827
04/11/18 03:11 PM
04/11/18 03:11 PM
ME
eljefino Offline
eljefino  Offline
ME
Good catch on the lug bolts. My w123 came with different length ones depending on if it had steel or alloy rims. If I used the wrong ones they'd either go all the way through the hub and catch on stuff or not get enough threads engaged to be safe.
Re: Aftermarket wheel lug torque [Re: pda1122] #4723831
04/11/18 03:13 PM
04/11/18 03:13 PM
TN
tnt31 Offline
tnt31  Offline
TN
I have bought two sets of tires and wheels from DTD (both times MB Wheels). Both times DTD included recommended torgue for the lugs on the paperwork I received and it matched the owners manual recommendation for the car. YMMV
Re: Aftermarket wheel lug torque [Re: pda1122] #4724078
04/11/18 07:40 PM
04/11/18 07:40 PM
pa
benjy Offline
benjy  Offline
pa
lugs are specific to wheels as seats + or length can vary. i always torque OE + some alloy wheel manufacturers recommend a retorque after 100 miles!
Re: Aftermarket wheel lug torque [Re: pda1122] #4724114
04/11/18 08:21 PM
04/11/18 08:21 PM
Arkansas
mazdamonky Offline
mazdamonky  Offline
Arkansas
When I bought my last set of wheels, there was an instruction sheet indicating they should be tightened to 85-105 ft lbs. I believe that sheet came from Tirerack. Pretty much what I do is use a wrench and just put my foot on it and lean into it. I have noticed with aftermarket lugs, I often have to retighten them after the first drive any time I remove them and put them back on.
2018 mazda3 hatch 2.5 263 miles
1985 rx7 1.1 98k miles
2002 protege 220k miles
1985 rx7 with a 5.0 swap
2002 Protege 299k miles Girlfriend's
4 more running cars in yard not mentioned
