Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
22 registered members (Black, iontrap, Bailes1992, Ether, ctechbob, BretK, 1 invisible), 843 guests, and 41 spiders.
Topics295,008
Posts4,925,907
Members66,664
Most Online2,553
Oct 27th, 2018
Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil #4708268
03/27/18 08:05 AM
03/27/18 08:05 AM
Michigan
bennybigb Offline OP
Michigan
Hello All,
We are using 0-40 M1 Euro oil for some track cars we have (BMW E30, Early 80s Celica, Miata and Volvo). My concern is the oil is possibly too thin for really hot days and I'm worried about Shearing and overall Oil Pressure. The Moly/Zink PPM is 1000/1100.
Should I add a quart of M1 VTwin 20-50 oil to our mix? The Moly/Zink PPM is 1600/1750 which is very close to the M1 Racing Oil Specs and it is of course thicker, which would help us on very hot days. I don't know if the Motorcycle Oil with it's Wet Clutch additives would be bad for our car or would somehow not mix well with the car oil?
Another option is to add a quart of M1 Diesel Oil.
What do you guys think? Thanks for the help!
Ben
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: bennybigb] #4708286
03/27/18 08:24 AM
03/27/18 08:24 AM
MN
oil_film_movies Offline
MN
Adding only 1 quart should be fine. It is hard to tell if the oil film in critical areas is bottoming out, so a guess for sure. Viscosity does create a thicker oil film in more parts of the engine, so its safe to do.
Probably better to just put in 100% M1 15w50 made for cars, like they recommend for high-performance Corvette track cars. Mixing those 2 you mention should be fine. I think the VTwin oil has an HTHS around 6, so you'd be boosting your overall HTHS from about 3-ish to around 4 with that mixing.
HTHS definition: high temperature, high shear viscosity, which governs how thick hydrodynamic oil films are inside your engine. Also, more of your engine avoids metal-to-metal contact among the bearing surfaces (rings, cams, crank, chain, all) the more hths you have.
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: bennybigb] #4708298
03/27/18 08:43 AM
03/27/18 08:43 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Run pure Valvoline VR1 oil and be done with it! M1 is junk these days... use a real race oil instead of a CAFE approved, EPA loving, Toyota Camry oil!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: bennybigb] #4708302
03/27/18 08:49 AM
03/27/18 08:49 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
How about a dedicated racing oil instead of trying to make your own? Ed: HEY, WHAT A COINCIDENCE!
If you want the job done right......do it yourself.
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: racin4ds] #4708304
03/27/18 08:49 AM
03/27/18 08:49 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
I guess a 05 Hyundai and a 08 Subaru are top of the line also???? LOL
2017 VW Jetta SE TSI 1.4L Turbo (hers)
M1 Euro 0W40 & FU (19K)
2008 Acura TL 3.2L PPPP 0W20 & FU (108K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
QSHM 5W30 & FU (96K)
2000 Ram 4X4 5.9L (93K) PYB 10W30 & FU
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: bennybigb] #4708313
03/27/18 08:57 AM
03/27/18 08:57 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Originally Posted By: bennybigb
Hello All,
Ben
Either flavor won;t hurt a thing.
Welcome to the BITOG Blenders Society. Been doing it for almost 25 years and never an issue.
She's the only sister-in-law I have. But she's not my favorite.
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: racin4ds] #4708318
03/27/18 09:00 AM
03/27/18 09:00 AM
MN
MN
You know they make a 10w60, which would be perfect in your hot-rod Tucson Korean car. Only woosies would use less viscosity.
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: bennybigb] #4708328
03/27/18 09:06 AM
03/27/18 09:06 AM
Michigan
Michigan
VR1 is not a synthetic oil, I still want extreme temperature protection.
They used to sell Synthetic VR1, but I don't see that stuff for sale anymore frown
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: bennybigb] #4708333
03/27/18 09:09 AM
03/27/18 09:09 AM
Here is the M1 spec. Is there something wrong with it? Better let the Nascar guys know.
Specifications and approvals
Mobil 1 Racing 0W-50 is recommended for a wide range of race engine applications. Note: Mobil 1 Racing 0W-50 is not recommended for street use.
Mobil 1 Racing 0W-50 is recommended for a wide range of race engine applications including highly loaded flat tappet designs such as NASCAR Cup engines.
Mobil 1 Racing 0W-50 is designed for use by professional, amateur and weekend racers.
Mobil 1 Racing oils are not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Technical details
SAE Grade 0W-50
Viscosity (ASTM D 445)
cST @ 40C 100
cST @ 100C 17.2
Viscosity Index 189
Sulfated Ash, wt% (ASTM D874) 1.3
HTHS Viscosity, mPa s at 150C (ASTM D4683) 3.8
Pour Point, C (ASTM D97) -54
Flash Point, C (ASTM D92) 221
Density at 15.6 C g/ml (ASTM D4052) 0.85
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: bennybigb] #4708334
03/27/18 09:10 AM
03/27/18 09:10 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
I'd still bet it holds up better than that M1 will...
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: BAJA_05] #4708336
03/27/18 09:12 AM
03/27/18 09:12 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Not getting your sarcasm or point?? I never said anything I have is top of the line, they are my commuter cars and get treated very well though wink
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: Snagglefoot] #4708393
03/27/18 10:15 AM
03/27/18 10:15 AM
Oakville, Ontario
Patman Offline
Patman  Offline
Oakville, Ontario
Technical details
SAE Grade 0W-50
cST @ 40C 100
cST @ 100C 17.2
Viscosity Index 189
I'm curious as to why the HTHS is relatively weak for such a thick oil? There are oils out there that are 40 weights with roughly that same HTHS. (for instance, Amsoil 0w40 with a viscosity of 14.8 cst at 100c has an HTHS of 3.76) I would think an oil that thick would have an HTHS closer to 4.2 or 4.3.
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 148k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,110k, GC 0w40 & Fram Ultra
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: bennybigb] #4708403
03/27/18 10:21 AM
03/27/18 10:21 AM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Why not just use M1 15w-50 to begin with? On the bottle it says it's specifically for racing engines. I'm not a Mobil fan but if you wanted Mobil there is your solution.
2010 Ford Escape 2.5~91K Miles: AMSOIL SS 5W-30, AMSOIL SS FE ATF.
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30, AMSOIL OE MV ATF.
AMSOIL
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: bennybigb] #4708405
03/27/18 10:22 AM
03/27/18 10:22 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Neither is the Mobil 1. - It's JUST SEMI. Not saying bad or good as ELF studies on F1 blends showed a semi blend to work better. Now, Blends of WHAT IDK. I used M1R 4T decade ago to boost HTHS and adds, but it went non-synthetic as it is formulated today.
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Mix 1 Quart of M1 VTwin 20-50 Oil with M1 0-40 Oil [Re: racin4ds] #4708500
03/27/18 12:14 PM
03/27/18 12:14 PM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
That was in response to your quote -- "Mobil One is junk."
