KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
27 registered members (Bailes1992, 2015Corolla, alcyon, 1WildPig, ArrestMeRedZ, 1 invisible), 816 guests, and 36 spiders.
Topics290,965
Posts4,853,483
Members66,063
Most Online3,590
Jan 24th, 2017
Ford FE Sludge #4668926
02/17/18 06:01 PM
02/17/18 06:01 PM
Shelton, WA
Chinook4u Offline OP
Shelton, WA
I have a 1964 Ford Galaxie with the 352 and 4 barrel. It has around 80,000 original miles and is basically a show car/ weekend cruiser. I have owned it for about 5 years. Anyway, the car runs great, but the one issue I have is that there's significant sludge in the engine.
When I first got the car, I took off the valve covers to find sludge along with gel, fir needles, and various other junk in the oil valleys. I painstakingly cleaned it all out. One thing to know about these cars is that removing the oil pan is not an option without at least partially pulling the engine. There's a frame cross member that sits right below the pan.
Having done some research on sludge, I opted for a slow approach to cleaning in fear of clogging the oil pickup. For the last 5 years, I have run Mobile 1 10w - 40 full synthetic high mileage oil in combination with the Mobile 1 filter and ZDDP additive. The idea being that frequent oil changes with a high detergent oil would slowly and safely clean the engine of the sludge.
So, I have done six oil changes at 500-mile intervals for the 5 years I've owned it. Even now, the oil turns absolutely black within a 100 miles or so. I do realize that the color of the oil isn't an indicator of viscosity etc. and in some respects, it shows that the detergents are doing the intended job. This regiment is obviously getting expensive.
Here's my question(s): Should I just continue doing what I've been doing (If it's not broke don't fix it.)? Or, should I try something more aggressive like MMO, Seafoam, or some other engine flush to help speed up the process?
I realize that pulling the engine would be the best bet, but I have plenty of other cars and projects that I need to dedicate my time and money toward. I'm leaning toward a more aggressive approach mainly because it bugs me to see thick black oil within a 100 miles or so, but I could be talked out it. Your opinions would be greatly appreciated. Thanks!
Re: Ford FE Sludge [Re: Chinook4u] #4668931
02/17/18 06:06 PM
02/17/18 06:06 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Put some Havoline DSPro Full Synthetic in it and a new filter see what happens to the sludge.
2004 Corolla 124831
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Ford FE Sludge [Re: JohnnyJohnson] #4668934
02/17/18 06:10 PM
02/17/18 06:10 PM
Wisconsin
WiskyBadger Offline
WiskyBadger  Offline
Wisconsin
What will that achieve?
14 Buick Verano �Blanche� 61k Castrol Edge & Delco filter
01 Ford Ranger �Rick� 166k Castrol Magnatec Motorcraft
78 Chevy Stepside
11 Chevy Traverse 114k Carquest 5w30 and Carquest filter
Re: Ford FE Sludge [Re: Chinook4u] #4668936
02/17/18 06:12 PM
02/17/18 06:12 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
I think you could safely increase your interval if you were trying to save some coin.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Ford FE Sludge [Re: Chinook4u] #4668940
02/17/18 06:17 PM
02/17/18 06:17 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Did you remove the valve cover in between OCI to see if it's getting cleaner?
What about cutting open the oil filter to see what it's trapping?
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Ford FE Sludge [Re: Chinook4u] #4668941
02/17/18 06:17 PM
02/17/18 06:17 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I'd do a 5 minute engine flush. You can substitute a quart of oil with kerosene instead of buying
this: https://www.amazon.com/Motor-Medic-MF3-5-Minute-Flush/dp/B000AME4V4#customerReviews
Me: 13' VW GTI 3 door 6 speed manual
Re: Ford FE Sludge [Re: JC1] #4668942
02/17/18 06:20 PM
02/17/18 06:20 PM
Shelton, WA
Shelton, WA
I have done both. The engine top end is pretty clean. There's no sludge blockage in the oil valleys. I have cut open the filter twice. The first time, there was grit (not metal, but more like sand/dust) and the second time, there didn't appear to be anything significant.
Re: Ford FE Sludge [Re: JC1] #4668944
02/17/18 06:21 PM
02/17/18 06:21 PM
Shelton, WA
Shelton, WA
Re: Ford FE Sludge [Re: Chinook4u] #4668945
02/17/18 06:25 PM
02/17/18 06:25 PM
Idaho
CorvairGeek Offline
CorvairGeek  Offline
Idaho
I'd continue exactly what you are doing.
Jerry
Re: Ford FE Sludge [Re: Chinook4u] #4668955
02/17/18 06:36 PM
02/17/18 06:36 PM
MN
14Accent Offline
14Accent  Offline
MN
Sounds like a really nice car!
With all the money spent on trying to "clean out" the engine, is there any reason you don't just yank the motor and go through it? Even with low miles, it's probably well overdue for a refresh.
It wouldn't even need a full rebuild, per se. Just pull the motor, strip it down to the long block, clean everything really really well, install new cam/lifters/timing kit, gasket kit, and maybe a fresh coat of Ford blue paint. Something that easy to work on, it's probably a couple week winter project at best.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Ford FE Sludge [Re: 14Accent] #4668963
02/17/18 06:45 PM
02/17/18 06:45 PM
Shelton, WA
Shelton, WA
As I mentioned, I realize this is the best approach, but one I'm trying to avoid at least for now. I have 7 cars -- not including my wife and kids cars. No, my house doesn't look like a used car lot! lol I just finishing a 1964 Ford Fairlane restoration project and I'm wrapping up a 1964 International Scout restoration (Red Carpet Series). Once that's done, I'm moving on to my 1976 Scout II (Patriot) restoration.
Re: Ford FE Sludge [Re: Chinook4u] #4668964
02/17/18 06:46 PM
02/17/18 06:46 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You can clean the pan inside along with all the junk that has accumulated on the bottom safely.
Get a gallon of cleaner from gumout, berrymans, etc.
Drain the oil on a warm engine and put the drain plug back in.
Through the dipstick tube only fill 3 qts of the cleaner in. You want it in the pan only not the heads or the oiling system, it will not touch any gaskets or seals but will liquefy the sludge and clean the pickup.
Do not use more as it will touch the main seals and possibly damage them. Keep the car/engine level use 4 stands or ramps and stands to do this if you cant get to the plug with the car on the ground.
Let it sit 24 hours and drain, do not turn the engine over then drain it. Flush it through with kerosene then cheap oil before turning the engine over.
Do a couple of short idle only oil changes with cheap oil then refill with regular fill, new filter and do normal OCI.
Edit: Add link.
https://www.walmart.com/ip/Carburetor-Pa...13=&veh=sem
Re: Ford FE Sludge [Re: Chinook4u] #4669011
02/17/18 07:39 PM
02/17/18 07:39 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I would keep doing what you are doing. A flush is always a risk for not a lot of gain.
2015 Ford F250 w/Powerstroke
Re: Ford FE Sludge [Re: Chinook4u] #4669013
02/17/18 07:41 PM
02/17/18 07:41 PM
MN
14Accent Offline
14Accent  Offline
MN
YOU, my friend, are a busy man! I retract my previous statements. With all that going on, it sounds like you're pretty much doing what you should. Would it be worthwhile, say, to drain the oil, slap on a fresh synthetic filter, and fill with an 80\20 mix of oil and kerosene or several bottles of the best engine flush followed by a long idle session in the driveway? Like on a Saturday afternoon, while working on other projects just let it sit and purr.
Or would there be a benefit, given the likely state of the pan, to drain the sump and fill with JUST solvent? Hear me out: you fill the empty sump with solvent through the dipstick tube. That way it doesn't coat the rest of the internals. Let it sit, maybe even with a heater under the oil pan, for a few hours or even days. Then take out the plug and drain, dumping a couple quarts of cheap whatever oil through the fill hole to wash the pan out. Then fill and new filter. Run at idle, drain and repeat.
Might be a long process but you won't have to pull the engine.
Re: Ford FE Sludge [Re: WiskyBadger] #4669016
02/17/18 07:49 PM
02/17/18 07:49 PM
Wet side WA
Wet side WA
This Havoline is suppose to get rid of sledge. But its good to see you on BITOG learning something.
2004 Corolla 124831
2006 Duramax 74277
