Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
97 registered members (AndyB, alphadog, 69Torino, Aero540T, 2009Edge, 9 invisible), 1,780 guests, and 39 spiders.
Topics295,003
Posts4,925,766
Members66,664
Most Online2,553
Oct 27th, 2018
OCI Length and Need for Synthetic Filter? #4664651
02/13/18 09:45 AM
02/13/18 09:45 AM
N/A
ffxfina3 Offline OP
ffxfina3  Offline OP
N/A
I've got a 2000 Honda Insight that I've done 7500 mile OCIs on for the life of the car. That car now has over 203,000 miles on it. Also, I've used oversized Baldwin and Hastings filters on this car. I change the filter every oil change. My UOAs with Blackstone are always very good.
I now own a 2015 Toyota Prius Plug-in. Toyota recommends a 10,000 mile OCI. Toyota does not require synthetic filters for this car. But I'm curious/concerned about going 10,000 miles on a traditional filter. (Granted, probably about 10-20% of those 10,000 miles, the car is driven in EV mode, so we aren't really putting 10,000 miles on the filter.)
Still, at what length of OCI is it generally understood that one should switch to a synthetic filter? I'm tempted to go 10,000 miles with a regular filter, check out the filter, and do a UOA and see what happens.
2000 Honda Insight - M1 EP 0W-20
2015 Toyota Prius Plug-In - M1 EP 0W-20
2004 Gravely 34Z - Amsoil ASE 10W-30/SAE 30
Re: OCI Length and Need for Synthetic Filter? [Re: ffxfina3] #4664669
02/13/18 10:01 AM
02/13/18 10:01 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
The OE cartridge for my car is cellulose media and the factory recommend filter interval is 30k miles.
Most German cars are on a 10k/1yr OCI with cellulose media. Some of the same cars have a variable interval in Europe, and go up to 30,000 kilometers between changes.
"Zed's dead baby, Zed's dead."
Re: OCI Length and Need for Synthetic Filter? [Re: ffxfina3] #4664671
02/13/18 10:05 AM
02/13/18 10:05 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
If you are concerned , just use the OEM filter .
Wyr
God bless
Re: OCI Length and Need for Synthetic Filter? [Re: ffxfina3] #4664690
02/13/18 10:19 AM
02/13/18 10:19 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
I have repeatedly run 10k and even some 15k mile OFCIs on "normal" cellulose filters (Wix and TGs).
Taking the filter apart only proved to be an exercise in futility; boring and nothing wrong.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: OCI Length and Need for Synthetic Filter? [Re: ffxfina3] #4664772
02/13/18 12:20 PM
02/13/18 12:20 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Personally I think the synthetic filter thing is more marketing than anything, but I do happen to use one; Fram Ultra.
If you want the job done right......do it yourself.
Re: OCI Length and Need for Synthetic Filter? [Re: ffxfina3] #4664776
02/13/18 12:25 PM
02/13/18 12:25 PM
Thatís an excellent data point. What weight and grade were you running? I assume synthetic?
Re: OCI Length and Need for Synthetic Filter? [Re: Snagglefoot] #4664828
02/13/18 01:56 PM
02/13/18 01:56 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Marketing does work wonders.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: OCI Length and Need for Synthetic Filter? [Re: Snagglefoot] #4664843
02/13/18 02:10 PM
02/13/18 02:10 PM
N/A
ffxfina3 Offline OP
ffxfina3  Offline OP
N/A
Thanks for everybody's replies. Nice to hear that traditional media is probably OK. I think I'll stick to my mentioned plan and examine the media and do a UOA and go from there.
Assume you are referring to the Insight. I've used three different oils over the life of the car -- all 0w-20. Started out with Pennzoil Platinum. I used PP until 134,970 mile mark. Then, I switched to the expensive Eneos Sustina. I used that until 179,990 mile mark. I've used M1 EP for the last 23,000 miles.
-Bryan
Re: OCI Length and Need for Synthetic Filter? [Re: CT8] #4664885
02/13/18 02:53 PM
02/13/18 02:53 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The reason filter makers recommend sythetic media filters with syntheic oil is because most people run longer OCIs with synthetic oil, which means the filter should have a higher holding capacity to match that longer OCI.
That's based on holding capacity measurements done in the lab testing, not based on how it looks after use.
Re: OCI Length and Need for Synthetic Filter? [Re: ffxfina3] #4665015
02/13/18 05:42 PM
02/13/18 05:42 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
The TRD is another choice from Toyota and gives full synthetic media. Hybrids and plug in hybrids are not necessarily easy on oil. They often run short times and turn off. On my Volt my gas used since last Sept is 1.5 gals over 1300 miles. I don't drive a lot. All the charging was free. I am trying to run the engine more this year. Today I drove it 10 miles on the engine, which gets it warmed up properly. It won't go on again for another two weeks or more. On the 07 Prius bought new it always had 5K changes, and I wouldn't go 10K no matter what anyone says.
Re: OCI Length and Need for Synthetic Filter? [Re: ffxfina3] #4665030
02/13/18 05:54 PM
02/13/18 05:54 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Use the OEM filter and continue with 7.5k OCIs.
She's the only sister-in-law I have. But she's not my favorite.
Re: OCI Length and Need for Synthetic Filter? [Re: dnewton3] #4665076
02/13/18 06:29 PM
02/13/18 06:29 PM
Western S.C.
CR94 Online content
CR94  Online Content
Western S.C.
Same story here, except my change intervals were more typically around 17k, and my cellulose filters were mostly Purolators (before their tearing epidemic), plus a few orange Frams and one Toyota (Denso).
People worry too much about non-problems!
2011 Toyota Prius now at 94K
Re: OCI Length and Need for Synthetic Filter? [Re: goodtimes] #4665083
02/13/18 06:34 PM
02/13/18 06:34 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Curious on what kind of OCI/FCI does the manual shows. I can see how the engine on a hybrid might be used pretty inconsistently, and therefore could make a set schedule too general. Maybe they use an OLM that takes into account how many miles or hours the engine ran vs how many miles the car traveled in total (?). Most automakers today say change the oil every year regardless of mileage.
Re: OCI Length and Need for Synthetic Filter? [Re: ZeeOSix] #4665120
02/13/18 07:09 PM
02/13/18 07:09 PM
Western S.C.
CR94 Online content
CR94  Online Content
Western S.C.
Originally Posted By: ZeeOSix
... Curious on what kind of OCI/FCI does the manual shows. I can see how the engine on a hybrid might be used pretty inconsistently, and therefore could make a set schedule too general. Maybe they use an OLM that takes into account how many miles or hours the engine ran vs how many miles the car traveled in total (?). ...
No, nothing that finely tuned. Toyota likes to keep things super-simple for us dummies. Thus, there's no true OLM, and no difference in oil recommended or in their recommended change intervals for hybrids vs. most of their other models. 0W-20 for everything, everywhere in the USA, every 10k (5k for adverse conditions), year-round.
Re: OCI Length and Need for Synthetic Filter? [Re: CT8] #4665174
02/13/18 07:49 PM
02/13/18 07:49 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Canadian pricing on the lower tier Fram stuff is a lot more obnoxious than it is for the Ultra. I can get something similar or better to a regular Fram for much cheaper. But, the Fram Ultra on special winds up being cheaper than the competition of that tier (i.e. Mobil 1, Wix XP, NAPA Platinum), and by a significant margin.
I like the Fram silver can, but it's hard to justify an $11 Fram silver over an $8 Wix or a $12 to $13 Fram Ultra. Both the orange can and silver can here have positioned themselves in no man's land, at least as far as I'm concerned. I suspect their sales, thanks to market penetration, would suggest otherwise, but that's another matter.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
