OP is specifically asking if the oil pan heater will extend the engine life, not if it's going to hurt anything. In my opinion it will not make a lick of difference. I would simply use what the manufacturer recommend a, check the oil level regularly and go over other systems. It is a 200k beater and the engine is not the only thing that can put this vehicle out of commission.
