Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
104 registered members (ArrestMeRedZ, aquariuscsm, acme, 69Torino, allgm59, asand1, 6 invisible), 2,039 guests, and 61 spiders.
Topics286,236
Posts4,904,920
Members67,582
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
FRAM XG Ultra Filter Efficiency #4594064
12/04/17 03:28 PM
12/04/17 03:28 PM
Clovis, CA
Merkava_4 Offline OP
Clovis, CA
That filter filters so well, that any darkness in the color of the oil is from combustion byproducts, correct ?
Re: FRAM XG Ultra Filter Efficiency [Re: Merkava_4] #4594082
12/04/17 03:49 PM
12/04/17 03:49 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Seriously???
Time to search. There's a ton of reasons for darkening of the oil. Very few due to nominal particle size in pcmo.
Re: FRAM XG Ultra Filter Efficiency [Re: JHZR2] #4594101
12/04/17 04:00 PM
12/04/17 04:00 PM
Clovis, CA
Clovis, CA
Originally Posted By: JHZR2
Seriously???
Yes seriously. You could have answered the question using less words than what you chose to use.
Re: FRAM XG Ultra Filter Efficiency [Re: Merkava_4] #4594111
12/04/17 04:08 PM
12/04/17 04:08 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
I thought that the oil getting a bit darker was a sign that it was working correctly, that is getting the additives to work and suspending particles. Many of these particles are too small to be filtered out and for the most part, don't cause problems as they circulate thru the system.
Re: FRAM XG Ultra Filter Efficiency [Re: OneEyeJack] #4594118
12/04/17 04:14 PM
12/04/17 04:14 PM
Clovis, CA
Clovis, CA
OneEyeJack - are you saying that the particles that are too small to be trapped by the filter are what contributes to the oil getting darker ? Are those same particles dirt particles, or are they combustion byproduct particles ?
Re: FRAM XG Ultra Filter Efficiency [Re: Merkava_4] #4594145
12/04/17 04:39 PM
12/04/17 04:39 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
IMHO-combustion byproducts (soot/carbon), which should eventually stick together & be captured by the filter (or the oil pump screen if they get too big).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: FRAM XG Ultra Filter Efficiency [Re: Merkava_4] #4594190
12/04/17 05:31 PM
12/04/17 05:31 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Get white paper towel and put a drop on it. You can see the debris settle out in rings, biggest chunks first.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: FRAM XG Ultra Filter Efficiency [Re: SHOZ] #4594258
12/04/17 06:56 PM
12/04/17 06:56 PM
Clovis, CA
Clovis, CA
ok then so the debris that settles out, is it dirt or combustion byproducts ?
Re: FRAM XG Ultra Filter Efficiency [Re: Merkava_4] #4594262
12/04/17 06:58 PM
12/04/17 06:58 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Where would dirt come from?
Re: FRAM XG Ultra Filter Efficiency [Re: SHOZ] #4594274
12/04/17 07:14 PM
12/04/17 07:14 PM
Clovis, CA
Clovis, CA
I'm assuming either through the air filter or around the air filter if the filter box is not well sealed.
Re: FRAM XG Ultra Filter Efficiency [Re: Merkava_4] #4594306
12/04/17 07:45 PM
12/04/17 07:45 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Yes, and yes and some additives get darker as well. A PCV system can contribute as well.
You should not let the oil get too dark if your car employees a chrome muffler bearing with digital framus matter seals on the isotonic pre-lubrication fittings.
If you use standard chrome muffler bearing you don't have to worry. Your OLM will be calibrated correctly. If you do have to replace those chrome muffler bearings here is a video to explain what you have to do. Even if you don't tackle the job yourself you will at least know what your mechanic is doing. Just make sure he is BFD certified.
Re: FRAM XG Ultra Filter Efficiency [Re: OneEyeJack] #4594665
12/05/17 07:59 AM
12/05/17 07:59 AM
Texas
Dallas69 Online content
Dallas69  Online Content
Texas
WHAT?
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Smittys 5-30
Motorcraft filter
Re: FRAM XG Ultra Filter Efficiency [Re: OneEyeJack] #4594695
12/05/17 08:38 AM
12/05/17 08:38 AM
Texas
4WD Offline
4WD  Offline
Texas
Is that an oil ranking test jig?
Re: FRAM XG Ultra Filter Efficiency [Re: OneEyeJack] #4595502
12/05/17 10:45 PM
12/05/17 10:45 PM
SACRAMENTO, CA
rrounds Offline
rrounds  Offline
SACRAMENTO, CA
If I have a dual exhaust system, do I need two of those?
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
Re: FRAM XG Ultra Filter Efficiency [Re: Merkava_4] #4602184
12/12/17 10:59 PM
12/12/17 10:59 PM
Virginia, usa
Shata Offline
Shata  Offline
Virginia, usa
Darkness like mentioned are a lot of factors one being carbon or soot, with bypass filter you can slow the process down a lot up until about 3k mile range. My oil in my truck stays clean almost like from the jug after that it slowly starts to darken to the 5-6k mark when I change it. But to answer your initial question no bud full flow like farm no matter what type of how expensive it is will not slow down the color change or get even close to filtering down to 2-3 micron.
16 Silverado 2500 LML 20k Miles
Rotella 5w-40 T6
ST 75w-90 GL5 Diff.
ST Full Syn Dexron VI ATF
Fram Ultra XG9100, AC Delco Fuel
CAT Coolant, K&N Air, K&N Cabin
Filter Mags: Fuel, Allison, LML
Page 1 of 3 1 2 3
