Separating toddlers from their parents?
by fdcg27
27 minutes 23 seconds ago
gm 8.6 truetrac
by Spitter
32 minutes 17 seconds ago
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
43 minutes 21 seconds ago
Rockauto 5% off
by Spitter
45 minutes 8 seconds ago
fumoto oil valve
by Santo
58 minutes 24 seconds ago
Grand solar minimum...
by ridgerunner
Today at 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
Today at 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
Today at 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
Today at 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
Today at 07:06 PM
Needing New Dipstick
by Geauxtiger
Today at 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
Today at 04:35 PM
Premium guard oil filters
by Jaha24k
Today at 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
Today at 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
Today at 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
Today at 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
Today at 02:58 PM
House A.c. vent leaking water
by motor_oil_madman
Today at 02:55 PM
"synthetic" gear oil and LS additive?
by nthach
Today at 01:54 PM
Supertech wix ST8 5514 miles
by jakewells
Today at 01:38 PM
Santo, aligoodn, memyself, MichiganKid419, kaphouston
65273 Registered Users
104 registered (addyguy, 2002 Maxima SE, AITG, Aero540T, 2015_PSD, 9050lx, 15 invisible), 1554 Guests and 30 Spiders online.
65273 Members
67 Forums
285622 Topics
#4590286 - 11/30/17 07:18 PM Dual oil filter relocation kit PH8A
oil pan 4 Offline
Loc: Hampton, VA
I never had anything that used this common ford oil filter.
So I think there is a most unlimited options.
It's going in a big block suburban so I have unlimited room too.
Had to do an oil filter relocation due to headers wanting to be right where the oil filter is.
What would be a extra capacity better than fram PH8A equivalent?
Heavily modified 1984 6.5L suburban.
#4590327 - 11/30/17 07:57 PM Re: Dual oil filter relocation kit PH8A [Re: oil pan 4]
Nick1994 Online   content
Loc: Phoenix, AZ
If you wanna get technical, the XG8A grin2
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4590336 - 11/30/17 08:05 PM Re: Dual oil filter relocation kit PH8A [Re: oil pan 4]
Donald Offline
Loc: Upstate NY
Put in a bypass setup if your going to relocate. I would. I did in my pickup.
Headers in a Suburban???
I don't get it. Suburbans are for pulling horse trailers and a bunch of people to the horse show.
Edited by Donald (11/30/17 08:06 PM)
2015 Ford F250 w/Powerstroke
#4590344 - 11/30/17 08:13 PM Re: Dual oil filter relocation kit PH8A [Re: oil pan 4]
Linctex Offline
Loc: Waco, TX
De-burr and chamfer all the oil passages in both the filter mount and the part that goes on the block. NO SHARP ANGLES - this is pretty important.
Do not use -08 AN lines, step up to -10 lines.
Oh for PETE'S SAKE - - - you will never ever ever ever need more flow than what two XG8A's can handle!!!!
#4590362 - 11/30/17 08:26 PM Re: Dual oil filter relocation kit PH8A [Re: oil pan 4]
ron17571 Offline
Loc: AZ
Everyone wants leaky headers.Never mind the RPM range where they actually do any good.Emissions and tune of a vehicle. Consider a glass pack muffler if noise is what you want.
2003 Dodge Caravan 140.000 miles
1992 Ford f-250 217,000 miles
#4590377 - 11/30/17 08:45 PM Re: Dual oil filter relocation kit PH8A [Re: oil pan 4]
FFeng7 Offline
Loc: Va
The larger version of the PH8A would be the PH977A. I have read that filtering efficiency is less than the standard PH8A.
2002 Dakota Quad Cab 4x4-Delo XLE 10w30-Fram XG16 Filter
2007 Cobalt LT-Valvoline Maxlife 5w30-AC Delco Filter
#4590408 - 11/30/17 09:26 PM Re: Dual oil filter relocation kit PH8A [Re: oil pan 4]
E150GT Offline
Loc: San Antonio, TX
Baldwin B7311MPG. That would be awesome with two of those.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 250k 5w30
2016 Mazda6 Touring 6MT - 56k 10w30
#4590488 - 11/30/17 11:20 PM Re: Dual oil filter relocation kit PH8A [Re: FFeng7]
Linctex Offline
Loc: Waco, TX
The larger Motorcraft is the FL-299 oil filter.
Yes, for SOME weird reason.... the "Huge" oil filters have really bad efficiency numbers, like 30 microns nominal or some ridiculous number.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3501528/Motorcraft_FL299_vs_FL1A_oil_f
STICK WITH XG-8A filters for best filtration.
#4598042 - 12/08/17 12:25 PM Re: Dual oil filter relocation kit PH8A [Re: oil pan 4]
oil pan 4 Offline
Loc: Hampton, VA
This is actually a 454 bored and stroked to 489 with aluminum GMPP heads, 11:1 compression, 270 adv. duration roller cam. Running sock manifolds would be kind of dumb.
It's also going to have cutouts, so it won't be loud, it will sound like the end of the world. But still have a normal relatively tame full exhaust system for normal driving.
I had no idea the larger filters lost efficiency so bad. Thank you.
I will use 5/8 line, I was thinking the 1/2 inch line looked a little small for a system trying to pump as much as 20gpm of oil.
Edited by oil pan 4 (12/08/17 12:26 PM)
