4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
95 registered members (AdditiveOCD, 4WD, 2010Civic, 69Torino, Agnosto, 11 invisible), 1,611 guests, and 69 spiders.
Topics286,042
Posts4,901,379
Members67,551
Most Online2,967
Mar 10th, 2019
Welder type for DIY exhaust work? #4586359
11/27/17 09:33 AM
11/27/17 09:33 AM
Around the corner
koffy Offline OP
koffy  Offline OP
Around the corner
My xterra as well as my sisters sienna developed a large exhaust leak,,, something common here in LI NY, so I was thinking about buying a cheap flux welder to do it myself. However, reading on the web people say that those welders are not good for this kind of stuff, that I should get a good mig welder, but those are not cheap, keeping in mind that I wonít use it often, I donít know if it really make sense.
Re: Welder type for DIY exhaust work? [Re: koffy] #4586362
11/27/17 09:36 AM
11/27/17 09:36 AM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
How about renting one? If it is only for a one-time use, it would not make a lot of sense to buy one.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: Welder type for DIY exhaust work? [Re: koffy] #4586375
11/27/17 09:47 AM
11/27/17 09:47 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
around here at least the right place would fix all that for cheap.. do you have a lift?
You will probably need one to weld it properly.
Re: Welder type for DIY exhaust work? [Re: koffy] #4586380
11/27/17 09:52 AM
11/27/17 09:52 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
You can probably replace the exhaust with new system without a welder.
People use gas to cut rusted-out sections.
I have had a place use a welder to make up an exhaust for my Jeep from SS pipe. That was TIG welding.
If parts are rusted they should be replaced not patched.
Do you know how to MIG weld. If not you will be burning through a lot.
2015 Ford F250 w/Powerstroke
Re: Welder type for DIY exhaust work? [Re: koffy] #4586381
11/27/17 09:53 AM
11/27/17 09:53 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Is it a hole in the pipe? Can you just put a pipe joiner clamp around it?
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Welder type for DIY exhaust work? [Re: Donald] #4586402
11/27/17 10:15 AM
11/27/17 10:15 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
A LOT... a lot a lot a lot
Rusty exhaust pipe isn't the type or place to "learn" to weld.
Re: Welder type for DIY exhaust work? [Re: koffy] #4586450
11/27/17 11:02 AM
11/27/17 11:02 AM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
This seems like one of those things that you come in with high expectations and end up destroyed, don't even bother.
If you're not already good with a welder your options are realistically:
1. Replace the rusted part of the exhaust.
2. Cut the rusted part out and join the pipes by making a lap joint with a band clamp, connector, reducer or flex joint connector and some U-clamps (obviously not going to work if the opening is on a catalytic converter).
3. If the hole is small just wrap a band clamp around it.
Options 2 and 3 are extremely cheap, less than twenty dollars in material cost and have a higher chance of working (if you measured and removed any rusted fasteners or clamps, nearly 100% chance of working).
2015 Civic LX Coupe
Re: Welder type for DIY exhaust work? [Re: NoNameJoe] #4586475
11/27/17 11:39 AM
11/27/17 11:39 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I bought a cheap $99 welder to do those types of repairs. It's a pain in the neck to do. Next time i just bought the whole section of pipes and replaced it.
Unless you want to invest the time to learn proper welding techniques and have ample time to burn, it's probably better to find alternatives to fixing stuff.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Welder type for DIY exhaust work? [Re: koffy] #4586549
11/27/17 01:23 PM
11/27/17 01:23 PM
Around the corner
koffy Offline OP
koffy  Offline OP
Around the corner
Ok,,, I guess It was not a good idea,, to many cons,, itís usually the flanges and flex joints,,, Iíll ask my friends for a good shop to take care of it,,, we canít always win (DIY everything )
Tanks guys your help is appreciated
Re: Welder type for DIY exhaust work? [Re: koffy] #4586626
11/27/17 02:37 PM
11/27/17 02:37 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
A lot of newer cars have exhaust sections that bolt together. Cut off the old rusty bolts from the damaged section, bolt-in a new one with new flange gaskets.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Welder type for DIY exhaust work? [Re: koffy] #4586632
11/27/17 02:42 PM
11/27/17 02:42 PM
USA
mk378 Online content
mk378  Online Content
USA
When a pipe gets rusty enough that one hole opens up, there will be more soon afterward. You're ahead to bite the bullet and replace the whole section, usually that means do everything from the converter to the tailpipe as a group. And any sort of DIY exhaust work is not fun.
Re: Welder type for DIY exhaust work? [Re: koffy] #4586693
11/27/17 03:34 PM
11/27/17 03:34 PM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I used the good ol' harbor freight boogermaster to weld my exhaust together. It's not pretty as it's a pretty thin gauge to get a good weld with the HF model. Held up great for a few years with no leaks. Ultimately a poorly placed boulder ripped the entire exhaust system off ... but not at my welds! So I took a different route.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Welder type for DIY exhaust work? [Re: Miller88] #4586706
11/27/17 03:44 PM
11/27/17 03:44 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
Originally Posted By: Miller88
boogermaster
LOL!!! That's exactly what it is. crackmeup
They sell pieces of flex joints. For the flanges, you can just cut the flange out and replace with a section of pipe connector or a reducer.
It just means that where you had to take the nuts and bolts off to undo the flange coupling, you now have to take off some U clamps and slip the pipes out of the connector or reducer.
If the flange used spring bolts, those slip and move under tension as the engine vibrates and is usually used as an alternative to a flex joint in the exhaust system. Replacing that with a straight rigid section may not be so good, they sell flex joint sections for this purpose.
2015 Civic LX Coupe
Re: Welder type for DIY exhaust work? [Re: koffy] #4586711
11/27/17 03:46 PM
11/27/17 03:46 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That will never work for exhaust tubing. Flux core wire burns way too hot for thin material like that. You need steel that's at least a 1/4 inch thick. I just saved you a lot of frustration.
Re: Welder type for DIY exhaust work? [Re: koffy] #4586742
11/27/17 04:14 PM
11/27/17 04:14 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
A good Lincoln MIG welder is $800. It should be 220v. You want to use gas for shielding unless your welding outside in the wind, then maybe flux core.
