Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
43 registered members (bbhero, Ag76, ArrestMeRedZ, Agnosto, Brad_C, Bailes1992, 6 invisible), 947 guests, and 57 spiders.
Topics286,170
Posts4,903,516
Members67,572
Most Online2,967
Mar 10th, 2019
Mixing 0W-20 Idemitsu and 10W-40=5W-30..? #4583338
11/24/17 02:53 AM
11/24/17 02:53 AM
NY
TurboTravis Offline OP
NY
Hey guys,
I picked up a bunch of Idemitsu 0W-20 from Advance Auto on clearance. I have always understood that mixing oils of different weights will net the average viscosity of the oils used in the mix. With that said, I recently changed the oil in my truck (2005 Chevy 5.3L) and beater car (2000 Honda Accord 2.3L) with a 50/50 mix of Idemitsu 0W-20 and 10W-40 (various brands used). Will be changed at the standard OCI or in the case of the Honda, probably earlier. Curious what you guys think of this.
Thanks
Travis
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: TurboTravis] #4583340
11/24/17 03:06 AM
11/24/17 03:06 AM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
I think it would be fine, especially for an older vehicle with lower specs. I wouldnt do a long interval, but its so cheap you wouldnt need to. A lot of forum members have tried it, just look up Frankenblend.
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: TurboTravis] #4583354
11/24/17 05:44 AM
11/24/17 05:44 AM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
It's fine and there's no such thing as "especially for an older vehicle with lower specs". No matter what the vehicle or specs, use the oil viscosity recommended for the operating environment whether you mix to reach that viscosity or buy it off the shelf that way.
If a vehicle has a lower service grade spec'd, that doesn't mean "just needs to be that good". It will also benefit from the higher modern spec oil, it's just that they couldn't spec something that wasn't available for testing at the time.
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: TurboTravis] #4583358
11/24/17 05:50 AM
11/24/17 05:50 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Dave9...how do you mix to achieve the desired properties ?
Can you provide us with (say) an SAE or API guideline on how to achieve your desired specifications and outcomes through mixing OTC certificated products ?
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: TurboTravis] #4583373
11/24/17 07:14 AM
11/24/17 07:14 AM
New York
pbm Offline
pbm  Offline
New York
I would guess that a 50/50 mix of 0w20 and 10w40 would result in something very close to a 5w30.
I probably wouldn't run such mix in the winter but see no issue running it in the other 3 seasons (because of unknown cold weather characteristics).
'Journalism is Dead'
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: TurboTravis] #4583427
11/24/17 09:03 AM
11/24/17 09:03 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
http://www.widman.biz/English/Calculators/Mixtures.html
*I bought the same oil for the same clearance price ($2.95 per jug and $.85 per qt). My 2.4 Sonata will be getting this 0W20 for some time. Incidentally, it is thicker at operating temps than many (recommended by Hyundai) 5W20.
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: Shannow] #4583429
11/24/17 09:09 AM
11/24/17 09:09 AM
Hither & Yon
Hounds Offline
Hounds  Offline
Hither & Yon
Originally Posted By: Shannow
Dave9...how do you mix to achieve the desired properties ? . . .
I'm going to guess he uses a funnel. grin
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: Hounds] #4583542
11/24/17 11:16 AM
11/24/17 11:16 AM
PimTac Offline
PimTac  Offline
And a Mk1 eyeball.
Cannot see signatures any longer so it doesn’t matter.
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: Dave9] #4583595
11/24/17 12:38 PM
11/24/17 12:38 PM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
I really didnt mean the API rating. I meant I wouldnt do it in an engine that calls for Dexos, BMW LL-04, etc.
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: TurboTravis] #4583604
11/24/17 12:48 PM
11/24/17 12:48 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
Originally Posted By: TurboTravis
Hey guys,
Thanks
Travis
I used to mix different oil weights all the time back in the day. We call it FRANKENBREW. You're not doing anything wrong. Keep on mixing!
thumbsup USA
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: pbm] #4583643
11/24/17 01:34 PM
11/24/17 01:34 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have a lot of full synthetic 0W-20 that I got on clearance,
but I don't like to tow heavy loads with it.
I add a little Syn-Blend Mystik 15W-50 (same as I run in my Evo Harley) for my "FRANKENBREW" in my F150.
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: wemay] #4583708
11/24/17 02:49 PM
11/24/17 02:49 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I have never seen anything of the fake evening News about cars spontaneously combusting from mixed oils. Sixty Nanoseconds would have never missed this chance if they could have pulled the wool over our eyes.
2004 Corolla 129987
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: JohnnyJohnson] #4583851
11/24/17 06:20 PM
11/24/17 06:20 PM
'Stralia
'Stralia
Yes..."nothing blew up" is the new performance standard in BITOG. "spontaneously combusting" is a handy little strawman, 'though, isn't it ?
Can't wait for the API to adopt it other than all those other expensive tests that go out the window when you mix. It will undoubtedly make for a less expensive product.
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: TurboTravis] #4583907
11/24/17 07:29 PM
11/24/17 07:29 PM
PimTac Offline
PimTac  Offline
For me, if I wanted 5w-30, I would purchase it rather than mixing some concoction of assorted oils. That is a waste of excellent Idemitsu oil.
Re: Mixing 0W-20 Idemitsu and 10W-40=5W-30..? [Re: PimTac] #4584084
11/24/17 11:17 PM
11/24/17 11:17 PM
NY
NY
It's all yours for the right price!
