Originally Posted By: billt460
For example, my 2015 Jeep Grand Cherokee is equipped with the 5.7 HEMI V-8. It has both MDS, (Multi Displacement System), and VVT, (Variable Valve Timing). Both require 5W-20 oil that meets or exceeds Chrysler Spec MS-6395 in order to operate properly. If you substitute a heavier weight oil, these systems won't function correctly. And you will have serious warranty issues if something gets damaged, and they can trace the failure to the wrong oil.
Does the MDS system work at 8cst, 12cst, 40cst, or 60cst ???? What IS the specified viscosity at 120F that makes the magic elixer work, and only that one work?
MDS requires 8 cSt, or 12 cSt or....
You can't say that the improvements in life are CAUSED by lowering viscosity...any rudimentary understanding of hydrodynamics and physics clearly points that thinner is NOT causing the increases we see in reliable life.
Understood. And I'm not saying, or suggesting that. What I am saying is going to an increased viscosity oil in these newer engines would not improve a thing. It would just cause issues. VVT and MDS have proven to have issues with higher weight oils. They are designed to operate on a very specific weight of motor oil.
Originally Posted By: zeng
What's the typical operating temperature, and hence typical oil operating pressure of a VVT in action , that a one grade thicker engine oil would not 'function correctly' ?
.... if a VVT not 'function correctly' was established to be 'solely' caused by thicker oil (in oil operating pressure ) ?
VVT requires 8 cSt, or 12 cSt or....
Mechanisms ?
Mechanisms ?
