VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
30 registered members (4WD, A1O, antik, billt460, bfleeman, ctechbob, 4 invisible), 497 guests, and 57 spiders.
Topics286,267
Posts4,905,521
Members67,589
Most Online2,967
Mar 10th, 2019
Best synthetic high mileage oils in 5W-20 & 0W-20? #4511474
09/09/17 11:12 AM
09/09/17 11:12 AM
USA
crazy_raccoon Offline OP
USA
This has probably been asked before but I can't seem to find a concrete answer to this. I know the majority of the off the shelf oils are practically all the same or yield similar results but is there a high mileage oil that actually comes out on top when it comes to wear, longevity and low NOAK? I'm thinking about using PPHM in 0W-20 on my next oil change since my car will reach about 100K at that time but it'll also be 11 years old by then as well. Hopefully you guys here would like to chip yalls 2 cents on the matter. Thanks.
'07 Scion tc
- 98K miles
- Valvoline FS w/ML 0W-20 D1G2
- FRAM Ultra
'07 Honda Accord coupe 4cyl
- 128K miles
- FRAM TG
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4511476
09/09/17 11:16 AM
09/09/17 11:16 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Define best? Best price best, best base oil, best additive package or best marketing. Oil is pretty much oil.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4511480
09/09/17 11:26 AM
09/09/17 11:26 AM
MD
AirgunSavant Offline
MD
What make and model of car? Engine?
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4511484
09/09/17 11:33 AM
09/09/17 11:33 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
In general terms oil that meets an API spec is about the same as any other oil that meets the same spec. They can be mixed and matched to your heart's content. An oil company must stop when it meets the spec because to invest more in time and resources would cause unneeded expenses and really cut into profits because they sell a lot of the stuff. Good enough is good enough. In fact, these oil companies often buy their base stock and additives from the same suppliers. You might be getting virtually the same exact oil with a different label. Let marketing fill in the fluff and present the product. Today cars most often fall apart, lose their appeal or rust away before the engine fails.
Today's 4-cycle gasoline poppet valve fuel injected engine using current engine oil is a marvel of design, development and mass production. It's been around for over 100 years and so far has resisted a takeover by any number of proposed replacements. As more challenges appear the good ole fashioned 4-cycle engine shows that it still has the "right stuff" and there's more to come.
Now, to answer your question. The only reasonable variables left for a given API spec are price and availability. Buy the cheapest, on sale oil that meets viscosity and spec's required for your application.
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: AirgunSavant] #4511498
09/09/17 11:52 AM
09/09/17 11:52 AM
USA
USA
2007
Scion TC
2AZ-FE
I already did 2 oil consumption tests due to my engine using about 1.5 to 2 qts. of oil between estimated 5K OCI's. I'm aware of the TSB on oil consumption but the dealer says I've passed both tests stating I didn't burn enough oil to report a problem with my motor. I've used off the shelf full synthetic oils 9/10 years of it's life so far mainly using Mobil 1 Full Synthetic and EP but switched to Pennzoil Platinum about 2 years ago.
'07 Scion tc
- 98K miles
- FRAM Ultra
- 128K miles
- FRAM TG
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4511514
09/09/17 12:23 PM
09/09/17 12:23 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
This would be my suggestion but you'll need to get three Jugs to get the free shipping.
https://www.walmart.com/ip/Castrol-GTX-MAGNATEC-5W-20-Full-Synthetic-Motor-Oil-5-QT/44580673
2004 Corolla 130017
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4511530
09/09/17 12:41 PM
09/09/17 12:41 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Valvoline Synthetic High Mileage.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: blupupher] #4511533
09/09/17 12:43 PM
09/09/17 12:43 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I'd go with Valvoline MaxLife (red bottle)syn-blend. Full synthetics seem to burn more not less with these types of issues.
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4511752
09/09/17 06:39 PM
09/09/17 06:39 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
MaxLife should serve you well.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4511821
09/09/17 08:09 PM
09/09/17 08:09 PM
Pennsylvania
K23Turbo Offline
K23Turbo  Offline
Pennsylvania
Don't know about best but I'd go M1 or Magnatec or whatever's on sale.
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4512294
09/10/17 12:34 PM
09/10/17 12:34 PM
Curtice, OH
Alex38 Offline
Alex38  Offline
Curtice, OH
Don't know about best, but I've had great luck with Valvoline MaxLife Blend in several older vehicles. Has stopped leaks and reduced consumption. That's what I'd try first.
2009 Ford Taurus X: 5w20 Valvoline SynPower
2012 Ram 1500 HEMI: 0w30 M1 AFE
2012 F-250 6.7 Powerstroke: 10w30 Rotella T5
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4512300
09/10/17 12:45 PM
09/10/17 12:45 PM
USA
USA
Thanks for the input guys. I've heard a lot of great things about Valvolines Maxlife but not a whole lot of Pennzoil Platinum High Mileage.
'07 Scion tc
- 98K miles
- FRAM Ultra
- 128K miles
- FRAM TG
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: Alex38] #4513119
09/11/17 11:13 AM
09/11/17 11:13 AM
USA
USA
I ended up buying a 5 qt. jug of Valvoline Full Synthetic w/Maxlife in 0W-20 since my next OCI will be in December - February. I don't know how this oil performs because all the information find are the Maxlife blends in 5W-30 that most people talk about online.
'07 Scion tc
- 98K miles
- FRAM Ultra
- 128K miles
- FRAM TG
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4513208
09/11/17 12:44 PM
09/11/17 12:44 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
All of them! Pick one!
Re: Best synthetic high mileage oils in 5W-20 & 0W-20? [Re: crazy_raccoon] #4513408
09/11/17 03:39 PM
09/11/17 03:39 PM
Sauk Valley, IL
EricBeau Offline
EricBeau  Offline
Sauk Valley, IL
I have PP 0W-20 regular synthetic about to go in my Odyssey but I plan on using MaxLife FS 0W-20 next time around. Hope it works out well for ya!
2001 Toyota Camry LE 4cyl.
Super Tech High Mileage 5W-30 and Super Tech ST4967
2010 Honda Odyssey LX
Mobil 1 High Mileage 5W-20 and FRAM TG7317
Ford Service Advisor
