pcv cleaning
by macdole99. 12/16/18 10:39 AM
Solar lights that last all night
by Snagglefoot. 12/16/18 09:20 AM
Things Santa might say......
by ZZman. 12/16/18 08:24 AM
ULTRA-POWER 57082
by ET16. 12/16/18 06:56 AM
No collision totaled vehicle
by madRiver. 12/16/18 06:32 AM
Brightest backup light for my daughters car?
by BobsArmory. 12/16/18 06:26 AM
M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
107 registered members (-SyN-, aba4430, 92saturnsl2, 69GTX, 2004tdigls, 94astro, 8 invisible), 2,276 guests, and 38 spiders.
Topics295,144
Posts4,928,584
Members66,691
Most Online2,553
Oct 27th, 2018
2001 Chevy 1500 #4448892
07/03/17 09:32 PM
07/03/17 09:32 PM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
company truck, which I've posted about before, with the 5.3 Vortec and 192k hard miles. We have been hauling dirt to build up the protection levees out of a high fence that holds exotic animals. (The owner of the animals has tons of dirt and lets the company I work for have it for free). My job for the past 2 months and most likely for the next 2 months, is to sit at the opening of the gate to make sure no animals escape while they haul dirt out. I drive 10 miles to the jobsite from the shop, then sit there and idle from 7am to 5pm with the AC on. It's extremely boring. Anyway I was wondering what would be the best oci and oil and filter to run in these conditions. I'm currently running Napa 10W30 blue bottle and a Napa Gold filter. It has an OLM but I've been changing it every 2k miles due to the extensive idling and some days I do pull a trailer with around 4,000 lbs. It runs hot every day unless I pop the hood and keep it open, once the hood is open its fine all day idling. Its been running fine otherwise since I've changed the intake gaskets and knock sensors. Should I do anything different in regards to oil and filter and oci?
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: 2001 Chevy 1500 [Re: mobilaltima] #4448896
07/03/17 09:36 PM
07/03/17 09:36 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Id probably do the same as what you're doing. How is the AC at idle like that? You might want to get an electric fan to keep the pressures down.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: 2001 Chevy 1500 [Re: mobilaltima] #4448920
07/03/17 10:21 PM
07/03/17 10:21 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
You can run the oil longer. Ford gives an hour of idle equals 30 miles of driving. If popping the hood keeps it cooler then that's what I would keep doing.
Check your coolant levels and quality. If it's degraded change it. A slightly lower temp thermostat could be useful. Pressure wash the radiator coils, that will help. Use some commercial coil cleaner if you're feeling motivated. If any of the coils are linked use a coil comb and open them back up. Check the fan clutch, make sure it is engaging properly.
The oil and filter are less important than the cooling system for your usage right now. If you want to avoid changing oil frequently pick up some m1 ESP in 5 or 10w 30 and run it to 15k equivalent
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: 2001 Chevy 1500 [Re: mobilaltima] #4448935
07/03/17 10:41 PM
07/03/17 10:41 PM
Gulf Coast, MS
3800Series Offline
3800Series  Offline
Gulf Coast, MS
It's a solid truck they can run well on virtually anything. Had the exact same truck and beyond a yearly distributor cap never had a problem with it.
The thing would not stop throwing codes but even then it ran very well. Original transmission went out at 330k miles (had it repaired since the thing still drove strong) head gasket went out at 380k and felt it was time to part ways.
Drove it up to the front yard (country area trucks are always in demand and a massive scrap/part junk yard 5 miles away). Not even two hours later I sold it for $550 (they knew about the gasket).
I have a good friend who bought on when he use to live up north and he had 520k miles truck ran great but the rust got to it bad.
I would personally go with a synthetic oil (Pennzoil, Mobil One, Castrol, Valvoline). With the tendency to run hot with the hood down the oil will last longer.
Re: 2001 Chevy 1500 [Re: mobilaltima] #4448970
07/03/17 11:27 PM
07/03/17 11:27 PM
Southeast Texas
gfh77665 Offline
gfh77665  Offline
Southeast Texas
Others will disagree, but I would use a SAE straight 30 or 40 weight.
Re: 2001 Chevy 1500 [Re: mobilaltima] #4449074
07/04/17 06:29 AM
07/04/17 06:29 AM
Golden Meadow, LA
Golden Meadow, LA
Electric fans are out of the question. This company is very cheap and would never spend the money for that.
Re: 2001 Chevy 1500 [Re: mobilaltima] #4449077
07/04/17 06:31 AM
07/04/17 06:31 AM
Golden Meadow, LA
Golden Meadow, LA
But today isnt bad. Sitting at the high fence as we speak in a 2016 Ram 2500 Hemi with dark tint, a radio that works great and cold AC. Happy 4th yall!
Re: 2001 Chevy 1500 [Re: mobilaltima] #4449083
07/04/17 06:45 AM
07/04/17 06:45 AM
Texas
Dallas69 Online content
Dallas69  Online Content
Texas
Why do you have to idle all day?
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Smittys 5-30
Motorcraft filter
Re: 2001 Chevy 1500 [Re: mobilaltima] #4449093
07/04/17 06:59 AM
07/04/17 06:59 AM
Golden Meadow, LA
Golden Meadow, LA
For the AC
Re: 2001 Chevy 1500 [Re: mobilaltima] #4449105
07/04/17 07:15 AM
07/04/17 07:15 AM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
10w-30 sounds great for the Louisiana heat. I grew up nearby in south Mississippi, and my father put 10w-30 in everything year round. Synthetic might be a bit better in the heat.
Re: 2001 Chevy 1500 [Re: Crispysea] #4449188
07/04/17 08:25 AM
07/04/17 08:25 AM
wv
krismoriah72 Offline
wv
If it were mine i would do the Rotella 5w40 and an AC Delco filter and change it every 200 hours or 200 gallons of fuel.
Re: 2001 Chevy 1500 [Re: mobilaltima] #4449371
07/04/17 11:33 AM
07/04/17 11:33 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Company truck? And you're only going to work there for 2 more months? I'd let them figure out the oil changes and not even touch it.
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: 2001 Chevy 1500 [Re: mobilaltima] #4449376
07/04/17 11:38 AM
07/04/17 11:38 AM
Golden Meadow, LA
Golden Meadow, LA
This particular job will last 2 more months.
Re: 2001 Chevy 1500 [Re: mobilaltima] #4449922
07/04/17 09:03 PM
07/04/17 09:03 PM
Crawfordville FL
Crawfordville FL
Put M1 or PP 10w-30 and run it to 10k equivalent. 300 hours would be about 9k miles.
M1 EP 5w-30 is good for 15k. 400 hours idling gets you 12k with 3k to drive. You should be able to finish out this job on one oci. I would use a Fram ultra filter.
If you can please UOA. I'm very curious to see how oil is affected by that much idling.
