Cleanliness
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
94 registered members (69GTX, A310, -SyN-, 4WD, 1foxracing, 9 invisible), 1,733 guests, and 46 spiders.
Topics295,175
Posts4,929,240
Members66,700
Most Online2,553
Oct 27th, 2018
Quaker State oil ? #4440125
06/24/17 07:15 AM
06/24/17 07:15 AM
Phoenix AZ
gmh101357 Offline OP
Phoenix AZ
Since Quaker State is owned by RDS and they own Pennzoil also would the two oils be almost the same? Im sure they come from the same refinery in Houston. QS is cheaper by 5-7 bucks for a 5 gallon jug.
Re: Quaker State oil ? [Re: gmh101357] #4440141
06/24/17 07:38 AM
06/24/17 07:38 AM
Indiana, USA
Smoqueed Offline
Smoqueed  Offline
Indiana, USA
As you can see here, they're not the same oil. However for all real world purposes, they should both perform about the same. So technically no, but realistically yes. Pennzoil uses their cool gas to liquid group III+ base-stocks, while QS supposedly doesn't. Regardless, they're both great oils and should hold up roughly the same.
Re: Quaker State oil ? [Re: gmh101357] #4440144
06/24/17 07:43 AM
06/24/17 07:43 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
QSUD and PP used to be indistinguishable from the LIMITED spec survey that PQIA performs.
Havent done a comparo recently.
In MY usage the Jury is still WAY out on the GTL basestock RDS is using in a lot of their brands.
Didn't cut it in the last Forester FB25 where VSP worked stupendously.
My Rogue is running HURT right now and I wasn't able to "hurt" it with Magnatec.
I have to go over the fueling/Induction system ONE MORE TIME before I can blame the oil.
Had rodent issues last year.
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Quaker State oil ? [Re: gmh101357] #4440180
06/24/17 08:28 AM
06/24/17 08:28 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
Shell says that no, they are not the same.
Re: Quaker State oil ? [Re: gmh101357] #4440183
06/24/17 08:31 AM
06/24/17 08:31 AM
Honda land
HondaRULZ Offline
HondaRULZ  Offline
Honda land
They're NOT the same if QS 10w has a ~5% NOACK and PP doesn't or hasn't released it?
QS 10W NOACK (look for this)
Re: Quaker State oil ? [Re: gmh101357] #4440227
06/24/17 09:19 AM
06/24/17 09:19 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
Who is RDS?
I thought that QS & Penn were both owned by SOPUS!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Quaker State oil ? [Re: Char Baby] #4440239
06/24/17 09:40 AM
06/24/17 09:40 AM
Phoenix AZ
Phoenix AZ
royal dutch shell
Re: Quaker State oil ? [Re: Char Baby] #4440241
06/24/17 09:41 AM
06/24/17 09:41 AM
Phoenix AZ
Phoenix AZ
royal dutch shell
Re: Quaker State oil ? [Re: gmh101357] #4440259
06/24/17 10:01 AM
06/24/17 10:01 AM
TX
maximus Offline
maximus  Offline
TX
Just a side note.
I seriously doubt motor oil is bottled in any refinery. Its most likely bottled by 3rd party regional contractors according to SOPUS' specs. There is a huge Shell facility in Houston, but they make fuel and raw chemical products for use in other industries.
SOPUS has a corp office in downtown which is why there's a Houston address on the containers. Motor oil is very small part of Shell's business.
2011 Sonata GLS.
Re: Quaker State oil ? [Re: gmh101357] #4440289
06/24/17 11:03 AM
06/24/17 11:03 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
The two companies are more or less run independently.
Even their 'branded' oil filters were made by different
oil filter manufacturers. The Pennz filter was made by Fram and the
Quaker State filters were not (don't recall).
That was a few year back, so they could be different now. I do know that
QS, or it's contractor for filters, had been shrinking some of their part
numbers. The *8A (PH8A) was suddenly the PH43 size.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Quaker State oil ? [Re: gmh101357] #4440310
06/24/17 11:45 AM
06/24/17 11:45 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Pennzoil filters are Purolator made, QS were Champ last time I checked (but it has been a long time since I looked).
As for comparing Pennzoil and QS, they are similar, but not the same. Conventional are very close from what I have seen, but Pennzoil is the top tier product, with QS (and then Shell) being the budget level oil.
There have been rumors that QSUD may have some GTL base stock if SOPUS has extra.
2018 Hyundai Santa Fe: Dealer oil and filter/5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: Quaker State oil ? [Re: gmh101357] #4440535
06/24/17 05:58 PM
06/24/17 05:58 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Quaker State oil filters, as well as Pennzoil & Performax oil filters, have been manufactured by Purolator for some years now. With the exception of the Pennzoil Platinum HE HPZ-XXX series, they appear identical internally and all have Purolator style date codes.
All these 3 brands are now "consolidated" with regard to filter sizes with lube shop inventory simplification and inventory / overhead minimization in mind.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Quaker State oil ? [Re: Char Baby] #4440748
06/24/17 11:05 PM
06/24/17 11:05 PM
MT
jongies3 Offline
jongies3  Offline
MT
Originally Posted By: Char Baby
Who is RDS?
Royal Dutch Shell is the parent company.
Shell Oil Products United States just pertains to their operations in the US.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM TG-3600 filter
1969 Mustang Mach 1 5.8 V8: PYB 10W-30 Napa Gold 1515 filter
1997 Ford F-250 HD 7.3 Powerstroke V8: T6 5W-40 FRAM PH-3786 filter
Re: Quaker State oil ? [Re: jongies3] #4441617
06/26/17 01:47 AM
06/26/17 01:47 AM
ROCHESTER, NY
ROCHESTER, NY
Who is RDS?
Thanks. All the years on this forum, I never knew that! smile
"Retired"
'15 Honda Civic LX
