Bought a Powermate 5500 Generator
by Miller88 - 11/18/19 06:10 AM
Amateur Paint Questions
by The Critic - 11/18/19 04:15 AM
What the..
by Mad_Hatter - 11/18/19 03:53 AM
Neighborhood Etiquette
by The Critic - 11/18/19 03:41 AM
AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0; 10w-30/5w-40 mix 8.6k miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
leafuntec, wolf777, Smittyzzz, JimBobSeeker, Joey737
69902 Registered Users
67 registered members (2002 Maxima SE, atomix8, Astro_Guy, 10ecfarmer, alchargo, 2010Civic, 5 invisible), 1,123 guests, and 20 spiders.
Topics297,574
Posts5,118,307
Members69,902
Most Online3,589
Nov 2nd, 2019
Page 1 of 5 1 2 5
hole in FRAM Ultra Synthetic leaked my oil out : #4319914 02/03/17 10:24 AM
Z
ZCJON888 Offline OP
Z
i have a 2003 honda accord LX V6 with 160,000 miles, i went to check my oil and was shocked to see that the dipstick was almost completely dry !!?, maybe just had a little bit of oil at the very tip end of it, but thats it, so i drove it slowly and carefully to a real close autozone and bought 2 quarts of oil, poured it in and drove over to a carwash nearby, and parked in the carwash stall, and turned the car off, and waited it to settle so i could check the oil level on the dipstick to see if it came up or not, and when i checked it, the dipstick still barely had anything on it!, even after just putting 2 quarts in it?, then i looked underneath the car real good with a bright light, and i saw a little stream of oil running down the pavement, then i looked to see where the drip was leading to, and there was no leak around the drainplug area, but then i saw that it was coming from the side of the oil filter, out of a small hole in it, and i don't have any idea how it happened ?, and i have never had that happen before either ?, but this one i got was a cheaper FRAM Ultra Synthetic (XG7317), but previously i always got Mobil 1 filters, but i thought that an oil filter is an oil filter, and they probably just do the same thing and thought it was fine just getting the cheaper FRAM instead, but i guess i was wrong ?
does anyone know of what types of things could cause that to happen to an oil filter ???, i just thought i would get opinions on this forum, since it has more knowledgable people that know about oil/oil filters and that type of stuff, and just so you know, when i tightened the filter when installing it, i first tightened it by hand til i could'nt turn it anymore, and then i gave it maybe one gentle turn using my oil filter wrench, (the squeeze type one, where its like pliers with 2 handles that you squeeze together and it clamps around the filter), but a guy on a different forum, where i made a post, said he thinks i still overtightened it ?, and he said really you don't even supposed to use an oil filter wrench at all, and also that you only supposed to hand turn it 3/4 to 1 turn after the gasket first makes contact, or something like that?, which does'nt seem like much ?, but maybe oil filters are just real fragile ?, or more than i thought ?
and by the way, all those scape marks around the filter and some of the dents, were most likely cause when i was yanking it around left to right, when i was removing it with the filter wrench, and i would'nt do it that hard if i were installing it, only when i know its old or bad like this one was, and that it did'nt matter if it was ruined while removing it or not, since i knew would'nt be using it again.
here is some pics of it, so you can see :
luckily i have another older 90 honda to use, and drove and got a new mobil 1 oil filter and new oil, (castrol edge syntec 5 X 30), and i put the filter and the oil in and ran it til the dipstick had the correct level on it, and drove car and no damage was done luckily, and checked to make sure no leaks were underneath and its all good, but i just wonder what caused the oil filter to form that crack or hole, that was leaking most of my oil out ???, and really i think it was probably some type of debris from the roadways ?, but i have read some things around the internet saying sometimes things like "oil pressure spikes" can cause an oil filter to rupture or make a puncture hole ?, so hopefully nothing internally from my engine did anything weird to cause it ?
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319918 02/03/17 10:27 AM
Yah-Tah-Hey Offline
That oil filter had damage caused by a tool of some sort. How in blazes did that filter get all of those gauges and scratches?
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319919 02/03/17 10:27 AM
L
Leo99 Offline
L
It's really chewed up. Was it that difficult to remove it that you had to bite into the filter with your pliers? Maybe it hit a rock or something. Hard to tell now if it was damaged while on the car or if you damaged it removing it.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319920 02/03/17 10:28 AM
R
redhat Offline
R
Lol is this a troll post?
That filter looks like it has been thrown against a concrete wall.
Who installed that filter? The whole grip texture is worn off. Better question, what was used to install it?
19 F150 2.7 - M1EP 5W-30, FL2062, 7k
17 Taurus Limited AWD - M1EP 5W-20, FL500S, 30k
84 JD 316 Repowered w/Vanguard 18
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319921 02/03/17 10:30 AM
E
EricG Offline
E
That's mechanical damage caused by either, improper installation or debris on the road! You should have to use you "Plier Type" filter wrench to tighten the filter. I know my channel lock filter wrench has semi sharp teeth on it.
11 F150 4x4 5.0
11 Cadillac SRX
03 Century
l
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319924 02/03/17 10:31 AM
R
redhat Offline
R
Also IIRC, the Fram Ultra has one of the thicker canisters when compared to other filters.
I am surprised you punctured it with a filter wrench.
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319925 02/03/17 10:31 AM
demarpaint Offline
Looks like the filter was damaged, not a defect.
God Bless Our Troops
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319933 02/03/17 10:34 AM
R
Rand Offline
R
who doesnt hand tighten filters? they only need to go 3/4 turn after gasket contact.
looks like you destroyed the filter removing it and decided to troll.
not saying you are.. just saying what it looks like.
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319934 02/03/17 10:35 AM
Danno Offline
The filter hangs down by the half-shaft. Check the 3 minute mark on the video.
Road debris could very well have caused the hole.
https://www.youtube.com/watch?v=BHp0GRHMt38
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319936 02/03/17 10:37 AM
R
redhat Offline
R
Any filter I put on is hand tightened, and removed by hand.
Jeez, my old filters are always in good enough shape that they could be put onto a beater with no worries.
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319940 02/03/17 10:38 AM
2
2civics Offline
2
Does seem like an elaborate troll job. Maybe not...
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: redhat] #4319944 02/03/17 10:40 AM
K
kschachn Offline
K
What do you think? The lack of capital letters, the run-on sentences, the general rambling over some weird problem. That is someone's hallmark writing style.
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319950 02/03/17 10:45 AM
V
Vladiator Offline
V
The guy on the forum is right. You have damaged the filter casing during installation with the filter wrench. Maybe barely, but just enough to make the filter burst during the first oil pressure spike. YOU SHOULD NEVER USE A FILTER WRENCH ON A CANISTER TYPE OIL FILTER DURING INSTALLATION! The rule is - get it hand tight. Not tool tight - HAND TIGHT. It is more than enough to hold the filter in place during the pressure spikes or any other abnormal incidents. And will make it a breeze to take off during the next oil change. I do 1 full turn after gasket touches the block. Service over 20 cars in the family and friends zone, and never a single oil filter issue/failure. Hand tight my friend, hand tight.
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319952 02/03/17 10:47 AM
J
John_Conrad Offline
J
that was damaged by installation, the same can occur when removing a filter that has been tightened too much upon installation.
if trolling, i'm IBTL, if not the above is the cause.
i do not believe a rock would cause that, it very much appears to be pinch damage from over torquing to remove or install.
on edit:
i have seen this type damage before. i have not seen the hole type damage itself, but all the scuff and folding weakens the case.
Safety doesn't happen by accident.--author unknown
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319953 02/03/17 10:47 AM
K
kschachn Offline
K
Dude knows that already.
Remember, these pictures are after the filter was removed.
1994 BMW 530i, 250K
Page 1 of 5 1 2 5
