Hi I'm new in the forum and registered especially for this question hope you can help me
I have a Toyota corolla 2004 with 3zz Fe engine that owned for 3 years at the start I used Toyota oil 10w30 that it burns about 1.5 Lt every 5000 km and had to clean the oil screen every year to clean oil sludge that was formed because previous owner changed oil every 15000 km now I I used different oil type max life and Mobil 1 the only oil that stopped the burn is liqui moly 5w40 now the problem is liqui moly is fine oil and clean the sludge well causing the oil screen to get dirty only after 1 month of use can I use liqui moly engine flush to clean what's left or what can I do I don't want to harm the engine
Thank you
Thank you
