Originally Posted By: bigt61
Just follow whatever is on the oil cap and you're good IMO.
Just to be nit-picky, I don't think Nissan puts the oil recommendation on the cap. There is usually a small sticker on the bottom-side of the hood that tells you what viscosity is recommended.
Having said that, what does the owner's manual say? If it says 5w30 is ok to use, then use that if it makes you sleep better.
