So been hearing and seeing all the bad about Motorcraft filters and decided to check some myself.
I cut open a used FL820S that looked good except the end glue was not attached to the steel cap on the threaded side.
Then I have 2 dented filters (Rockauto rejects) that I had on the shelf and cut them open. The 820S had very bad pleat spacing and some glue resin looked like it started to separate. I used a hacksaw so the damage to the media was from that.
The FL400S looked great.
I am feeling good about the 400s, but not so much on the 820. Think I will be using Wix next time as I can get the real WIX brand for under $4.00 through a work discount.
I was going to post the pictures but don't have my own webpage - never heard of needing that. If anyone wants the pictures I could send them.
