Friend of mine who has an old roadster prefers not to use HM in his hot rod since his father-in-law gave it to him and has only seen Valvoline, so he he has put in an additve which states on the back of the bottle will cure leaks, and if it doesn't, discontinue use and repair the leak. Not exaclty sure what his hang-up is with HM oils, but are these oil additives for stop leak any good? I'm not talking about that one which is thick and gummy, there is another one out which is the same viscosity as ordinary 5w or 10w-30.
With regard to my own HM vehicle, it still leaks, (slowly) even with the HM oil in it right now, and I'm wondering if I'm just waisting mone and should stick to the great rebate deals to be had on conventional oils? I'm sure this engine will still outliv the body....so any of you have an opinion on the HM or the additive and do you bother keeping on with them even if the motor still leaks?
