Originally Posted By: fpracha
Originally Posted By: Gokhan
Regarding fuel economy, 0W-20 and 5W-20 have identical fuel-economy criteria under GF-5. So, you aren't guaranteed at all to see any fuel-economy improvement whatsoever over 5W-20. A tiny (around 0.1 MPG) improvement may result under certain conditions, assuming the 0W-20 and 5W-20 oils have very similar additive packages. A 5W-20 oil with a better friction-modifier package can easily beat a 0W-20 oil in fuel economy.
There is really no cold-start benefit either unless you live in extremely cold climates (Canada, Alaska, etc.), as the cold viscosity is not that different from 5W-20.
So is it also possible and true then that a super-high-quality 15w40 oil with "more effective friction modifiers" can have a very similar (or just slightly lower) fuel economy as the 5w20 or 0w20 ?
Absolutely no. Fuel economy (engine friction) is mainly determined by the HTHS viscosity. Friction modifiers are secondary.
The current SAE limit on HTHS viscosity is 2.6 cP to prevent possible engine damage due to oil-film breakdown. Auto manufacturers have been trying hard to have the limit lowered further to satisfy future government fuel-economy standards. Note that diesel engines require much larger HTHS viscosity because they generate a lot of torque at low RPM, where the oil film is thin. CJ-4 minimum is 3.5 cP.
0W-20 and 5W-20 both have 2.6 cP HTHS viscosity. On top of that, GF-5 spec on fuel economy is the same for both. The actual efficiency will be determined by the amount and quality of friction modifiers. Also, used synthetic oil may have more fuel efficiency than used dino oil, as the synthetic oil deteriorates more slowly.
If the same additive packages and friction modifiers are used, expect to see only about 0.1 MPG improvement for using 0W-20 instead of 5W-20, due to slightly lower cold viscosity.
