Originally Posted By: SnowmanCO
IMO, Wix's performance numbers are correct (B2=20). It is just being interpreted incorrectly. Some people are saying 50% at 20 microns (which I would argue is incorrect - it's silly bad), and a few people have wondered if this really means 95% at 2 microns. The beta ratio's specified for Wix's normal filter line are in a completely different format, and I think that adds to the confusion (2/20=6/20 or 50% @ 6 microns, and 95% @ 20 microns). This topic is also discussed here:https://bobistheoilguy.com/forums/ubbthreads.php/topics/3322042/Article_from_Baldwin_-_%22U Fleece filters were originally developed by Mercedes to support better filtration over longer intervals, and MANN is the manufacturer for Mercedes using that design. Check out this forum -
https://mbworld.org/forums/c-class-w203/335009-wix-filters-question.html
Specifically:
"Oil filters!!!! - M+H filters are blown polyester - known as "fleece" They were developed with Benz for long drain with 229.5 approved oils. They are the only approved filter for V6 & larger engines & previously the M271. The K&N oil filter is a rebranded Mann fleece filter as is the Bosch. They are 1 micron nominal 3 micron absolute - 75 beta ratio filters & will comfortable achieve old ISO 16/11 cleanliness in one pass new. The only other filter I know that will do this off the shelf is a Donaldson Syntec synthetic media hydraulic filter specified similarly."
Not that everybody on every forum is correct, but this would make sense. It agrees with the B2=20 meaning 95% of 2 micron particles. I have a Mercedes C300 (using MANN OEM filter), and a Mazda 3 (Using Wix XP cartridge filter). The media on the filters is identical. Mercedes is well known for developing new technologies, and not limiting those technologies to spread industry wide in the automotive industry. Think ABS and Electronic Stability Control. The synthetic media for all Wix/Mann filters is most likely produces at the same facility, and then distributed to where the filters are manufactured. This is probably why the Wix support people don't understand the numbers. It's Mercedes/MANN technology being incorporated (not designed by Wix) into the Wix line. Wix is simply passing down the media filtering specs provided by MANN. My MANN filter is manufactured in Germany, Mazda Wix XP in Poland (where their standard filter is also manufactured), and my F150 Wix XP filter is made in the USA. That doesn't mean the media was made in Germany/USA/Poland.
Wix is a recent acquisition by MANN, the XP/Platinum has been around a lot longer than their corporate marriage. I have a couple of NAPA Platinums at home for my Cummins, I'm going to cut one and post the pictures. I would be really surprised if it's a "fleece" filter.
