Oil Filter Media Efficiency Spec's
TC
California
PART 1 OF 3
OIL FILTER MEDIA EFFICIENCY SPECIFICATIONS
I had time on my hands last week, so I compiled a list of oil filter media filtration specs pilfered from the InterTubes. I opted to not take the time to spreadsheet the data. A few notes…
1. CURRENT AND HISTORIC SPECS
The specs below include both current (2023) and historic specs, the latter for purposes of comparison and also for folks with new-old-stock filters in their garage.
2. BELLAVITA 2023 THREAD
For newer filters and media you might visit the excellent 2023 BITOG thread by Bellavita titled “Oil Filter Value Analysis.”
3. DATA SOURCES
The data below generally originates from four sources: 1) Manufacturers’ published specs; 2) Specs from major retailers; 3) Lab testing by various entities; and 4) Forum postings by individuals who directly received responses from filter manufacturers (“Motorcraft responded to my email and said the specs were…”). I suspect my sources are mostly authoritative, but occasionally imperfect, and many specs came from BITOG.
4. GENERAL VERSUS SPECIFIC MEDIA
Most data below are “general” specs for a broad line of filters, and some are specific to a given filter part number. So there’s plenty of room for inconsistencies – a given part number’s media can deviate GREATLY from the “general” media used by that same manufacturer. When such discrepancies arose, I often listed a range, such as 99%@40-50u. And sometimes manufacturers provide such ranges as well.
5. TESTING METHODOLOGY
I did not record the testing methodology used, SAE, ISO or otherwise, and in some cases it wasn’t provided anyway. So perhaps apples-to-oranges…the data is what it is.
6. EXPLAINER
I used the letter “u” for microns, close enough to the actual symbol. A human hair is roughly 75 microns thick, and beach sand is typically 0.3 to 60 microns. “99%@20u” means a filter media can remove 99% of particles 20 microns and larger. “99%@50u” means a filter media can remove 99% of particles 50 microns and larger. The “20” media is much more effective than the “50.” Figuratively think of the 20 as a paper coffee filter and the 50 as a pasta strainer, a greatly exaggerated example. The larger the first number the better, and the smaller the second number the better. A General Motors study concluded that “Compared to a 40 micron filter, engine wear was reduced 50% with 30 micron filtration. Likewise, wear was reduced by 70% with 15 micron filtration.”
7. OLDER AND LOW-VOLUME APPLICATIONS
Based on experience with my 20 year old camping trailer tow vehicle (a 2003 Range Rover with factory BMW engine), I’m fairly convinced that older and low volume filter part numbers simply don’t get updated. So in such applications you may be stuck with whatever media they were using 10, 15 or 20 years ago, and little if anything newer than that. It’s not worth their time to update the filter part number with a cool, new media if few people buy it. For example, I have various media specs for old BMW V-8 engines (not included below because they’re dated outliers), filters still made and sold today, and they’re basically lame compared to the latest media offerings.
8. STANDOUT MEDIA
There’s some standout media below, both good and bad. I’ll let others comment on that. Not all the cellulose media suck, and not all the synthetic media rock.
PART 2 OF 3
AC DELCO – 2011
95.4%@20u
AC DELCO – 2015
98%@25-30u
AC DELCO GOLD – 2021
90%@16u, 95%@19u, 98.7%@24u, 99.2%@29u
AC DELCO GOLD / ULTRAGUARD – 2023
98%@25-30u
AMSOIL – 2007
98.7%@15u
AMSOIL – 2011
98.7%@20u
AMSOIL EA – 2014
98.7%@20u
BOSCH PREMIUM – 2015 and 2023
99%@20U
BOSCH WORKSHOP – 2023
97.5%@40u
CHAMPION CHAMP / SUPERTECH – 2021
90%@20u
CHRYSLER / MOPAR – 2011
94%@20u
DONALDSON – 2023
99%@40u
FRAM – 2014
97%@20-30u
FRAM EXTRA GUARD – 2021
95%@>20u
FRAM TITANIUM – 2021
99%+@20u
FRAM TOUGH GUARD – 2015
99%@20u
FRAM ULTRA – 2014/2015
99%@>20u, >99%@20u
FRAM ULTRA – 2021
94%@10u, 99.8%@15u, 99.9%@17u
HASTINGS / BALDWIN – 2002
50%@22u, 98.7%@45u
HASTINGS / BALDWIN – 2010
50%@18u, 98.7%@40u
HASTINGS / BALDWIN – 2015
50%@12u, 98.7%@25u
HASTINGS / BALDWIN – 2019
50%@9.8u, 98.7%@27u
HENGST
No data, hard to come by.
HONDA – 2011
66.5%@20u
PART 3 OF 3
MAHLE – 2020
50%@13-18u, 75%@24u, 90%@28u
MANN – 2016
50%@20u, 99%@>50u
MANN – 2018
50%@14-20u, 99%@36-50u
MOBIL 1 – 2015
99.6%@25u
MOTORCRAFT – 2007
80%@20u
MOTORCRAFT – 2011
93.7%@20u
PUROLATOR BOSS – 2021
80%@23u, 90%@26u, 95%@28u, 98.7%@33u, 99.2%@38u
PUROLATOR BOSS – 2023
50%@22u, 99%@25-46u
PUROLATOR ONE – 2010
99.9%@20u
PUROLATOR ONE – 2023
Apparently three different media which vary significantly?
50%@10u,
PUROLATOR PREMIUM / CLASSIC – 2014
97.5%@20u
PUROLATOR PREMIUM / CLASSIC – 2023
ROYAL PURPLE – 2021
96.5%@15u, 98.7%@19u, 99.6%@29u
ROYAL PURPLE – 2022
80%@10u, 98.7%@20u, 99%@25u
TOYOTA – 2011
51%@20u
WIX / NAPA GOLD / CARQUEST BLUE – 2010
50%@8-18u, 95%@20u, 98.7%@25u
WIX / NAPA GOLD – 2014/2015
95%@20u
WIX / NAPA GOLD – 2016
50%@21u, 95%@44u
WIX / NAPA GOLD – 2017 and 2023
99%@23u
WIX PRO-TEC / NAPA SILVER – 2017 and 2023
95%@29u
WIX XP / NAPA PLATINUM – 2014/2015
50%@20u, 99%@35u
WIX XP – 2021
50%@18u, 71%@23u, 84%@29u, 89%@40u
Fantastic! Thank you Sir!
I use Purflux Oil Filters but I need to get in contact with the company on their Mircon Rating. They use Chevron Pleats for more Filter Media, I would think it would be a good Micron Rating too. I’ll post if I get an Answer.
Despite the marketing claims which oil filter will allow the engine to outlast your ownership of the vehicle
Why do you always troll with this type of comment in every thread about filter efficiency? Go do some research on engine wear vs oil cleanliness, it's been discussed many times. It's not hard to understand that with all factors held constant, cleaner oil will result in less wear. Every wear study makes that conclusion.
There are only two ways to keep the oil cleaner than not over an OCI: 1) Use a better oil filter, or 2) Change the oil. The longer the OCI, the more important the filter efficiency becomes. Once particulate gets in the oil, regardless of how it gets there, the best way to remove it is to filter it out. That's the whole purpose of any filter.
Thanks for this. I mostly use OE Mann or Mahle on our Euro fleet and found it interesting how low their efficiency is relative to other options. I also noticed the Toyota filter is also in the same range of efficiency. Makes you wonder how important 99.999999999999999999% efficiency really is.
I throw Fram ExtraGuards (gasp) on everything else because they're reasonably priced, good enough and the SureGrip is nice to have.
The Fram EG is rated at 95% @>20u. That's basically on the upper end of the available filter efficiency spectrum. IMO, anything 95% @ 20u or better is a decent level of filtration for most normal OCI.
Thanks!! I’ve been looking for Hastings/Baldwin info. Assuming spin on and cartridge are the same ratings I wanted to compare with the Fram TG I’ve been using for years on different vehicles. Looks like the Hastings is less efficient but I’m not sure if it’s that much of a difference filtering out the tiny specs of carbon that makes the oil “dirty” ??
Glad this proved helpful to folks. Now if only someone would micron rate the particles in my hazy India Pale Ale...
Any one of them are fine if ya just change your oil at a reasonable interval. Go high capacity/high efficiency if you don’t change the oil often or like to greatly extend ocis. Keep good air filtration. That simple.
PART 3 OF 3
MAHLE – 2020
MANN – 2016
50%@20u, 99%@>50u
MANN – 2018
MOBIL 1 – 2015
99.6%@25u
MOTORCRAFT – 2007
80%@20u
MOTORCRAFT – 2011
93.7%@20u
50%@22u, 99%@25-46u
99.9%@20u
50%@10u,
97.5%@20u
ROYAL PURPLE – 2021
ROYAL PURPLE – 2022
TOYOTA – 2011
51%@20u
95%@20u
50%@21u, 95%@44u
99%@23u
95%@29u
50%@20u, 99%@35u
WIX XP – 2021
Where is the Toyota spec from?
I didn’t remember the Motorcraft filters being that efficient. Almost 94% at 20 microns is quite good.
I wonder if there’s any test on them that is a little more current? We have certainly seen plenty of changes with filters since 2011, or 2020 for that matter.
I bought a few Fram Titanium FS5s per ZeeOSix's recommendation. Luckily some wired backed ones from 2021 were sitting on the shelf waiting for me. I'll be using those for a little while
