Originally Posted By: aquariuscsm
The Wix pleats look thicker and having less pleats,while the Fram's look thinner and having more pleats.
I count ~44 on the WIX and ~48 on the FRAM.
Maybe the WIX are slightly thicker (It really looks like they just aren’t folded as hard) but a lot of that appearance in the pictures is the size difference.
Originally Posted By: BlueOvalFitter
Originally Posted By: DuckRyder
My only issue with the WIX (other than price) is that the base end bypass and coil spring take up a fair amount of space and the element is correspondingly shorter.
Nothing really wrong with either filter.
You prefer the oil to flow over dirty filter media then enter the engine thru a dome type bypass?
None of this stuff really matters, but I prefer the media to fill up the can to the extent possible, particularly when the manufacturer filters don’t include a base bypass.
Interestingly enough, the XP version of this part number does not include a base end bypass.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4642025/
I read somewhere that these Wix filters (white can) have a black rubber adbv as opposed to a silicone one.
White WIX? The one I picked up was black and the ADBV was Silicone (It is in the tread linked in the previous post)
BTW, It probably also bears mentioning that I’ve cut open most of the common Honda fitment filters and some not so common, just search post started by me.
