Originally Posted By: Trav
Originally Posted By: LeakySeals
skyship your too much. Oil filters are not one-time screw on fitment. Where do you come up with this stuff?
God knows. Probably from the chaps on the bus.
This guy is the energizer bunny of misinformation, if he doesn't know he will just make it up then bounce off to give his expert insight on something else.
The chaps on the bus are geeks, but this would be one of many reasons from the manual:
1 - oil filter gasket itself, for one reason or another - if the filter gasket was not lubricated with oil before it was installed, or the filter has been on the vehicle for a long time, it can stay stuck on the vehicle when the filter is removed for an oil change.
If you have to remove an old oil filter and it is of the spin on type that does not allow the seal to be changed, then you have to fit a new filter according to the good books.
In reality you should tighten the filter only once when fitted and if it leaks it should be replaced, that way the face can be cleaned again in case any debris is stuck on it, so trying to use it as a drain is one bad idea.
Some new generation filters use better synthetic seals and do allow complete removal, cleaning of the fitment face and refitting, but I think they are mostly truck units.
