What about that Premium Passenger Car oil? What's the deal with it?Yes. If you order it use the forum code bitog15 for a discount
They both sound pretty good.
Thanks for that discount code also!!!
I’ve posted UOA’s for both oils if you search my post history. The no VII will combat fuel dilution a little betterWhat about that Premium Passenger Car oil? What's the deal with it?
Yeah, Valvoline is funny that way but they're not the only ones that do this. If you look at the Noack value in the spec sheet on some of their oils they'll just put <15 even though, because of the approvals, like MB, you know it's actually a maximum of 10. They do the same with pour points, they're just telling you it meets 0w.PAO with a pourpoint of -39°C? Or a 'PAO formula' at ~10 % PAO?
A 0W-30 with a true 'PAO formula' typically results in a pourpoint at -60°C.
SDS sheets are safety sheets. They will list only what is harmful to first responders.Yeah, Valvoline is funny that way but they're not the only ones that do this. If you look at the Noack value in the spec sheet on some of their oils they'll just put <15 even though, because of the approvals, like MB, you know it's actually a maximum of 10. They do the same with pour points, they're just telling you it meets 0w.
Also, if you look at the SDS, they're showing 30 to <40 % group 3 and don't list PAO but if you scroll down to the US State Regulations under Pennsylvania you'll see PAO listed. So what do you think the rest of the % is? It certainly can't be group 1 or 2 for sure for a variety of reasons.
Precisely.....and in Pennsylvania they're more strict on what's actually harmful or at least they want more info given on to better handle a situation, which is why they had to disclose it's got PAO, it's a PAO based oil.(..and so is their Euro 0w-40).SDS sheets are safety sheets. They will list only what is harmful to first responders.
Take it with reservations.
I would say 10% PAO at best.Precisely.....and in Pennsylvania they're more strict on what's actually harmful or at least they want more info given on to better handle a situation, which is why they had to disclose it's got PAO, it's a PAO based oil.(..and so is their Euro 0w-40).
I know full well what an SDS is and what to and not to conclude from it.
Opinion noted.I would say 10% PAO at best.
I would not say 30-40%. Castrol sells 0W30 on Amazon, and that is close to 50%.Opinion noted.
I would say more like 30-40% realistically.
You must be thinking of the Castrol Edge 0w-30 LL sold here on American shelves which is much more easily available. They have the ability to get away with more than Valvoline can. Bigger isn't always better.
Either that or your saying this Valvoline contains some esters, which i don't believe.
Generous? ..or perhaps disingenuous.I would not say 30-40%. Castrol sells 0W30 on Amazon, and that is close to 50%.
When I said 10%, I was being generous.
What are you talking about? There are different Castrol products. What each product they will offer and where is their decision. I am just saying that Castrol Edge 0W30 and 0W40 are close to 50%.Generous? ..or perhaps disingenuous.
Oh, Amazon. See, that right there is exactly what i'm saying, they can get away with this. Meanwhile, the version on American shelves is closer to the 10% that you rate Valvoline. Valvoline simply can't get away with this easily and only have 1 version(American) and you can buy it here in the USA and will be more PAO-based. It even has a lower kinematic viscosity at 104F/40C than this specific Castrol sold on American shelves.
