Originally Posted By: bullwinkle
His '85 305 has that darned electronic Quadrajet
If that's the case, then that's the source of the failure right there. I used to have a '78 Cadillac and it would never pass smog unless the carburetor was new. And it couldn't be a parts store carburetor either; it had to be custom carburetor built by a Rochester pro shop.
Sounds like [censored]. I have the E4ME electronic Qjet and she hasn't failed an inspection, everytime a smog test comes up on my 83 Silverado with the 305 she gets a thorough tune up, cap,rotor,plugs, air filters. Have you checked the timing, you won't get a true time with the distributor hooked up to the computer, disconnect the 4 wire plug to the distributor and set your base timing to 8* then reconnect the 4 wire plug, when was the last time the oxygen sensor was changed, if it's clogged you'll never get a good reading, check the PCV valve and clean or replace, change your oil and filter, I like to spray Gumout carb spray down the carburetor at high idle speed to clean out the intake passages and the carb, spray the exterior of the carb to clean it up, last and most important is take the truck out on the freeway and drive like you stole her, high speed for at least 10 miles to get everything HOT! this will also set the computer to the new readings with a new O2 sensor, ask me how I know, failed a smog test with a new O2 sensor, didn't drive it far enough for everything to marry up, took her back out and ran on the freeway, came back and she passed with flying colors
PS. I also put a bottle of GTP in the tank, just for fun
