How many miles until timing chain needs to be changed? 2016 Cmax SEL Hybrid?
I imagine they can last longer now but I have changed them back in the day.
My 2005 Chevy 5.3 is at 241,000 miles and still quiet as a mouse on the original timing chain. I change the oil at 5,000 mile intervals and use Valvoline Maxlife HM 10w30 . I’ve never considered a timing chain as a maintenance item…maybe I should.On the Mercedes, M116 V-8, it should be done about every hundred thousand miles.
On a small block, Chevy or Ford, I wouldn’t let it go much past that either.
I had a small block Ford (1970 302) jump time at about 120,000 miles. Loose chain. Worn gears, and it jumped a tooth.My 2005 Chevy 5.3 is at 241,000 miles and still quiet as a mouse on the original timing chain. I change the oil at 5,000 mile intervals and use Valvoline Maxlife HM 10w30 . I’ve never considered a timing chain as a maintenance item…maybe I should.
For the most part I think materials and knowledge have come a very long way since then. My last car went to 324k miles on the original chain, and the previous engine on my wife's Sonata went 215k on the original chain before the engine died due to the well known issues with the Theta-II engine family.I had a small block Ford (1970 302) jump time at about 120,000 miles. Loose chain. Worn gears, and it jumped a tooth.
Started the Ford one morning. Died. Refused to start again. Cranked OK.
Checked fuel at the carb, yep, spark, yep. Checked ignition timing. Off by nearly 20 degrees. Which was about one tooth on the timing gear. Replaced the timing set, started right up.
Not as much experience with the modern Chevy engines, but this was the days of nylon covered gears, and they sure didn’t last long before a failure like this. Everybody raves about timing chains, but I’ve done quite a few timing chains.
Good design. A short cam in block roller chain with added guides - looks like an easy 200K+ mile item.My 2005 Chevy 5.3 is at 241,000 miles and still quiet as a mouse on the original timing chain. I change the oil at 5,000 mile intervals and use Valvoline Maxlife HM 10w30 . I’ve never considered a timing chain as a maintenance item…maybe I should.
And unlike a *LOT* of other engines, the timing system for some Audi/VW engines is at the rear. Making it a mandatory engine-out procedure.
Especially if one does extended OCI where grits and bits can grind away at the links.For numerous reasons a timing chain no longer automatically equals zero maintenance.
