Originally Posted By: aquariuscsm
Originally Posted By: SR5
From this link,
http://datnet.org/topic/14125-castrol-qa-thread/
A Castrol tech did a few questions and answers.
Quote:
There is no such thing as the best oil.
The Castrol Edge range is formulated with different base oils to give the best results for the different engines each has been designed for.
You cannot judge the performance of an engine oil by its base stock.
Edge Sport 25W/50 is a mineral oil based on Grp II base stock, as it has been designed for older & larger 2-valve pushrod engines with roller rockers. Synthetics, like Grp IV base oils, do not build up a good film on roller rockers as well as a mineral oil, where valve train forces are very high.
Edge Sport 0W/40 & 10W/60 are synthetic Grp IV products and designed for engines with sliding valve trains or 4 valves or more per cylinder with roller rockers, where valve train loads are lighter than the 2 valve engines and where engine speeds are higher.
Edge Sport 5W/30 is a happy medium utilizing Grp III (HVI) base oils, which provide virtually all of the benefits of Grp IV but at a slightly lower cost.
Very interesting discussion! I like how Castrol is actually telling them what base stock each oil is using and not just saying the "Oh it's proprietary blah blah" nonsense. Great post!
You do realize they only told you what you wanted to hear. Their base oils are proprietary also.
