Only after the moving parts have gained enough speed to build an adequate MOFT. And when an engine is shutdown hot, the remaining oil film will be pretty small since it was fully hot (low viscosity) and will drain off as much as possible. If there is only the left over residual oil film inside the journal bearing without any new oil supply to the bearings, then it's hard to say if that remain oil film is giving full bearing protection or not for the first 4 or 5 seconds it may take to get fresh oil to them if the filter is installed dry and some galleries above it are also empty. The number of crank rotations in that short time period may only be around 50 revolutions, so even if there is some metal-to-metal contact it's going to be for a very short duration. Will it be noticeable wear over say 4,000+ start-ups in 200K miles (estimated) on the engine? It's a small sliver of all things that can cause engine wear so who knows for sure, but getting oil to the required parts ASAP is something positive IMO, regardless if doing so vs not can be detected from behind the wheel or not.At startup the oil is cold and has a high film thickness.
