If you’re driving a beater to skirt safety by getting a classic car license, you can still get a fix it ticket for a brake light etc whilst driving.
Friend, relative, even UPS store address. Insurance wants to know where it's garaged and where it will be driven. Doesn't really matter where it's registered. I have cars registered in Florida and Virginia and the renewals are sent to my Maryland address so they don't careNothing. Insurance would need the address/zip code of where the car is registered, so that would need to be legit.
They are pretty strict with regards to insurance here.
What's that have to do with safety?Just found out that Virginia's safety inspection won't fail a vehicle if the CV boot is cracked and spewing grease everywhere. The CV joint and boot are not part of the inspection.
No. CV joint failure will cause loss of drive to the wheels. Happened to me in an old Seville. Coasted to the side of the road and got a tow.Seems like a CV joint failure can cause loss of control of the vehicle, according to what I read.
Huh? When one CV joint breaks, there is no drive to either wheel, so no.That can cause a pull to the side that failed, which, if the driver isn't expecting it, can cause a wreck.
Maryland requires:
- INSPECT UNIVERSAL JOINTS/CONSTANT VELOCITY JOINTS FOR:
- Attachment and Worn, Damaged Or Loose Joints
- Torn or Damaged CV Joint Boot
You first mentioned Virginia.Maryland requires:
Different states have different requirements.Just found out that Virginia's safety inspection won't fail a vehicle if the CV boot is cracked and spewing grease everywhere. The CV joint and boot are not part of the inspection.
Only when purchasing a vehicle. After that you no longer have to do annual inspections. So, there's some serious beaters on the road with regular plates. Long as they pass that emissions test every other year they could care less...
I occasionally see Maryland vehicles around Northern Virginia, but never anything that called attention to itself for being a serious beater. Maybe they don't drive them into Virginia much.
It should be noted that classic registration, and classic insurance are two different things.In South Carolina "classic Car" is very restrictive, can only be used for official events like parades, etc.. A friend of mine lives in TN and has his registered as a classic - he can only drive it on weekends but insurance is very cheap.
As mentioned, just register it as a regular car.
And I had to re-aim my headlight, although it had passed several previous times in two other states and once previously in VirginiaSame reason as $20 oil changes. To get people in the door and sell them needed or unnecessary repairs. I'm sure the auto repair shop lobby would do all it can to maintain annual safety inspections in VA. And it's more than check the lights and horn. I had to replace ball joints and repair a slight exhaust leak to pass my Sequoia.
