Zee09
$200 Site Donor 2023
This is on a LF655- 3614 clone and I've seen it on the LF240, and on several Baldwin 14XX series
I contacted the company many times and no response.
This is about impossible to get a picture of but the center tube is deformed and not sealed against the base plate.
On this one it is 2/3rds the way open and at times near .150 " wide.
I had to darken the picture so you can see below the threads you see a bit of yellow media sticking through.
These have a bad base plate crimp that also holds the base plate gasket- it is uneven and does not stay put.
That is why I'm no fan of these.
This LF655 is a modern one with the silicone adbv.
