I know that...but why both?Some cars only have a maf and a barometer, (Volvo) and some only have a map (chevy) they both can be used to calculate air density and flow and volumetric efficiency, so you really only need one.
RedundancyI know that...but why both?
With the adjustable valve timing it is pretty easy to get 100% load values out of a NA motor. My old Accent with 190k miles can hit 100% at 6500 rpm! It has only the MAP.I'm not an engineer, but I've read that engines using valve overlap can get some complex airflow inside the inlet manifold that one sensor alone can't accurately measure.
Also, some engines use stratified charge mode (throttle valve fully open, engine speed/load controlled by injector pulse-width). A MAP sensor would be next to useless under these conditions.
