Originally Posted By: fuel tanker man
I wouldn't leave it in there... it could fragment and jam the oil pump, then you'll be in a mess.
Assuming it went in there through the oil fill, and you haven't started or cranked the engine... it's probably there near the oil fill. If you drained your oil... it might have moved toward the oil drain.
Find a mechanic with one of those fiber optic cameras and have him insert it into the oil fill and then the oil drain and you can at least find out where the thing is... here is one, so you know what I'm talking about:
http://www.homedepot.com/webapp/wcs/stor...amp;marketID=43
Snap-on has one that has a smaller snake on it that the one linked above...
I would think if it's 4 inches long, the end should have touched the bottom of the engine pan before it went all the way through the oil fill port... but I guess I'm wrong.
What engine and model of bike is this?
Dan
Its an 06 dyna and i had been able to snag it a couple of times with a coat hanger but couldnt get out far enough to grab it, then i drained the oil and now i cant even find it using a mirror and light, Ive tried one of those finger grabber tools and no luck. I may have to just drop the oil pan and deal with it that way. For now i am going to bed and sleeping on it before I twist off of something.
