1 FMF:
You mention that you are using an HD receiver. Is this HD receiver external to the TV? Is this the DirectTV tuner? If so, this may alter some of the following information. I just run the cable from the wall into my Sony and let the TV handle everything. Adding the dish to the equation may alter how things work. If the dish can receive the signals and just pass the unaltered signals through to the TV, then my findings may work for you.
- HD channel availability depends upon location. In the northeast where you are I would expect at least the big 3, (ABC, CBS, NBC), PBS, and FOX are brocasting HD signal via terrestrial signal, (i.e. standard air waves). These channels can be picked up by any standard antenna as long as the signal strength is strong enough. Keep in mind that an HD channel will not display at all if the signal does not meet a minimum strength requirement. It is not like standard broadcast signals which will can come in as a snowy, staticy picture if the signal is weak.
Via cable, many channels are broadcast in HD. Some of the channels have a twin channel(s) which broadcasts the same programs in HD. Some channesl, (like PBS), actually broadcast alternative programs on one of their HD channels.
The Sony HDTVs with the integrated tunner will recognize and automatically broadcast any HD signal it receives. I recommend using the auto-channel-program feature of the TV. It will take 30+ minutes, but it is well worth it.
The Sony TV has an onscreen display option which can be turned on to display information about the signal being received. The display will tell you if the signal is 480i, 480p, 720p, 1080i, etc. Even without the display, if the signal is an HD signal, you will know the difference.
All HD channels will be in 'DOT' format, (ex: 13.3). What the channels will be is specific to a broadcast region.
Most HD programs are filmed in 16:9 and so are broadcast that way. Some local shows, (like the news), are filmed in 4:3 and broadcast in HD at 4:3.
Most HDTVs, (including the Sonys), can alter the ratio of view of the program at the decision of the viewer. If you set the Sony to Full screen mode and leave it there, it will handle the picture ratio for all programs. In Full mode, the Sonys will take the 4:3 and stretch it to 16:9.
In most cases when using a new Sony HDTV, let the TV handle the settings. I have heard of plenty of people tweaking their HDTV to the point where the picture quality is not good. Just let the TV handle things, and enjoy the picture.
