Originally Posted By: SeaJay
Originally Posted By: 02SE
As has been said, The rust issues associated with Tacoma's, Tundra's, and Sequoia's, was due to Dana Corp making the frames improperly. Toyota won a multi-million dollar lawsuit against Dana Corp as a result. With the hassle and bad press, I'm sure Toyota has since taken steps to ensure that rust-preventive measures are taken as speced.
ANY new vehicle which is operated in a highly corrosive environment can have rust issues, if the instructions I've seen in every owners manual to keep the vehicle clean when operated in such an environment, is ignored.
I live in an area that salts the roads heavily all winter long. Back in my consumer car repair days, I saw vehicles from all the manufacturers with severe rust issues. I have friends who are still in consumer car repair that tell me nothing has changed in that regard. The common theme among those cars? Negligent owners.
https://www.bobistheoilguy.com/forums/ub...2/what/showflat
Bottom line: If you operate a vehicle in a highly corrosive environment, follow the owners manual instructions and wash off the salt as often as is necessary. Including the undercarriage. Also, protect the paint as necessary.
By me folks have their outside water spigots turned off for the winter to prevent damage from freezing water. Yes, you can go to the mechanical car wash, and then drive right back on the same wet roads with salt. Most folks wait until the roads dry to get it washed, but there will be days on end where the roads do not dry and it is pointless to wash until they do dry up. Salt is a fact of life during the winter in many places.
A fellow NY'er, you nailed it. They often salt in anticipation of snow and ice, and the roads can remain coated with the garbage until it rains and washes it away. Many cars have a layer of salt on them for weeks at a time, or longer, a sad reality.
From what I have read and been told, the damage from the salt occurs once the temperature goes above a certain point. An example the article I read stated, one of the worst things you could do was park a salt covered vehicle in a heated garage. The article suggested to park a salt covered vehicle outdoors and wash off the salt once the temperature allows.
Fortunately, I live in an area that only sees snow 2-3 times a year and when it does snow, the temperature moderates soon after allowing me to wash the vehicles.
